03-23-2009, 01:02 AM | #1 |
Rock Crawler Join Date: Dec 2008 Location: Appleton, Wi
| Winch modded TQ3???
I modified my tq3, and fitted a steering switch from an old transmitter to use as a winch controller. It works nearly flawlessly. The only problem is that when the winch servo I have is plugged in it rotates ever so slightly. My question is, is there any switches I can fit as a trim knob? I cant use the stock trim knobs from the donor transmitter because they are solder in connections and I wont have a way to mount it. sorry for the fuzzy cell phone pics. |
03-23-2009, 02:09 PM | #2 |
I was thinkin of just using another trim switch from an old tq2 or something. Do you guys think this would work?
03-23-2009, 04:03 PM | #3 |
Rock Crawler Join Date: Jun 2005 Location: Safety Harbor
On the back of the TQ3,lower left there is a pot that may help fine tune the 3rd channel.It worked for me but not that great.Every once in a while it would start to creep.Its just the way it is with the TQ3 and an anolog servo.I just installed an on/off switch to the servos power wire.Solved the problem.
03-23-2009, 04:27 PM | #4 |
Quarry Creeper Join Date: Oct 2008 Location: Spanaway, Wa
A freind had the same issue with his servo "creeping", sometimes it would stop if you touched the ant......swapped out the servo for a better one and now it's fine.
03-24-2009, 11:22 PM | #5 |
I was looking at that little adjuster and was wondering what that was for. Is that a trim switch for the third channel?
