03-23-2009, 05:13 PM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Clermont
| dx6i question
Just got a dx6i, and I want to keep it intact with the left stick non-return, in case I want to expand my horizons later. Using it that way, I want to use the right stick for throttle, since it is return to center, and since crawling is usually so slow, I don't see too much of an issue with having non return steering.. On the right stick though, how can I get it to go straight into reverse when I move the stick down. ATM, I move it down, and have to let it sit in the middle for just a sec or two. |
03-23-2009, 05:20 PM | #2 |
Pebble Pounder Join Date: Nov 2007 Location: Houston
That isn't a DX6i problem, that is your ESC that is preventing you from going from forward straight into reverse.
03-23-2009, 05:40 PM | #3 |
RCC Addict Join Date: Nov 2008 Location: Greece, sun, sea and rocks
Most probably you have to tap the brake or move a bit down, return to center and then move the stick down again. A tamiya teu 101bk ESC I use follows this pattern in order to reverse, thus preventing the car from reversing when in full speed.
03-23-2009, 05:50 PM | #4 |
