03-24-2009, 12:53 AM | #1 |
Rock Stacker Join Date: Jan 2009 Location: Bay Area
| cc bec to servo wiring
I have a hitec 5995 servo. all wires going in have same color insulation. which is pos, neg, sig wire? was going to wire cc bec directly to servo bypassing rx. also on the cc bec I am guessing red and brown are pos and neg?
03-24-2009, 01:01 AM | #2 |
Rock Crawler Join Date: Jun 2006 Location: LOMPOC
Yes the red on the bec is positive. The concern I have is that all the wires on the Servo are the same color. The way to figure it out is when you plug it into the RX. Look at the servo plug. the flat side should be on the bottom and the small sides should taper to the top. If you are holding it this way then the ground wire is on the right. That is the negative. then the middle wire is positive and the wire on the left is the info wire(forgot the name of this one.). HTH
03-24-2009, 03:46 AM | #3 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
Signal wire |
03-24-2009, 08:53 PM | #4 |
