10-06-2005, 03:43 AM | #1 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
| Smoked HS-5955TG
Well I got my MAXX crawler done & ready for it's shake down. Plugged it all together & after about a minute the front servo started smoking I'm running a SR, 2 5955TG servos, silver can motor, GD600, SMC3800 This sucks Brand new $100 servo fried just like that Anyone have this happen or know what could have caused this? Would Hitech warrenty this? Thanks :? |
10-06-2005, 04:24 AM | #2 |
Quarry Creeper Join Date: May 2004 Location: Boobslando, florida
I hope to GOD that the waranty covers that give them a call.. if you do some searching on that servo on the site I believe I have read about people smoking them when runing 2 of those with that same setup .. Im runing the same servo and I would flip if it were to fry good luck to you Arrrghh! 5995TGs Pissing me off! http://www.hitecrcd.com/cgi-bin/ulti...?ubb=forum;f=3 service@hitecrcd.com 858.748.8440 |
10-06-2005, 08:31 PM | #3 |
they will warrenty. I bet they had a bad initial batch, as a few did fry. There should be no reason for it with your setup though. I would worry about the SR's BEC overheating and frying before the servo. Call Hitec and get a new one. |
10-06-2005, 09:48 PM | #4 |
Thanks guys. Took it back to the LHS today, the owner exchanged it w/o question. Me happy again Damn I hope it doesn't happen again. Didn't even go crawling yet just down the hall. |
10-06-2005, 09:49 PM | #5 | |
What radio and reciever are you running?? That will matter more than motor, gear reduction and batteries. Perhaps you had the wires mixed and caused the servo to fry...maybe? How were your EPA settings adjusted? Does your radio have EPA settings? If not, you might want to pony up for a radio that allows you to adjust the EPA, it'll help save servos and keep them happier. | |
10-06-2005, 10:03 PM | #6 |
I have a JR xs3 pro. The servos are run of a 5-cell rx pack. the harness for the batt. to servo is staight from my TLT that no longer has 4ws. It worked on the TLT so I have no reason to believe that's the prob. I did set all the EPA's first w/o the Moabs on. Then took a little run down the hall. The turning radius isn't that good so I did an Austin Powers type turn, like a 8-point turn or something, then poof.
10-06-2005, 11:24 PM | #7 |
Rock Stacker Join Date: Jul 2005 Location: hawaii
are you takingyour cralwer out tomorrow? any pics yet?
10-07-2005, 01:30 AM | #8 |
Rock Crawler Join Date: Jan 2005 Location: Nanakuli
you know i was running 2 hs5955 and on my txt (the one you seen) and the front would turn but not the rear !! but fixed the problem there is something with those servos that they don't like each other ... any one on for saturady crawlin !
10-07-2005, 02:00 AM | #9 |
Rock Stacker Join Date: May 2005 Location: Ewa beach
ahhh DISTURBIN your servo went poof and mines went dead no power at all see when you was teasing me |
10-07-2005, 03:41 AM | #10 | |
10-07-2005, 04:02 AM | #11 |
Rock Crawler Join Date: Nov 2004 Location: Driving the Troysion Stick up the BIG BOY line!
I've never had any luck with the 59 series servos from Hitec. I've had 5 just fry or stop working.
