04-04-2009, 10:56 PM | #1 |
Rock Crawler Join Date: Jul 2008 Location: Dutch Oven - AZ
| Weird electronics glitch... HELP!
I have an AX10 RTR and I have modified it significantly, but still have the stock electronics. It started exhibiting some odd symptoms today. Basically, the throttle doesn't respond consistently, its just intermittent. As I pull the trigger to apply throttle, it does nothing for 4-5 seconds, then hops forward 1-4 feet and stops again. A few seconds later it does it again. The steering is fully responsive without any hiccups, the battery is fully charged and the wires seem to be all connected as they oughta be. Maybe I need a new ESC? Any thoughts on what the issue is? THANKS. |
04-04-2009, 11:01 PM | #2 |
Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
First test is to make sure your antenna wire isn't touching any metal or close to any other electronics. If you can for testing hold it completely away from everything and see if it still glitches.
04-04-2009, 11:15 PM | #3 |
has it has the chance to get any water what so ever? mine has worked ok for the while i have had it and if u want an inexpensive esc try the tazer 12t or 15t my friend just got the 15t and it works just fine and better than th axial 1 i have
04-05-2009, 10:17 PM | #4 |
absolutely no chance of water contact. Also the antenna seems to be fine, its not touching any metal. Sometimes when the truck isnt responding, I wiggle the wires and it works... Do I need to re-solder a connection? |
04-06-2009, 09:56 AM | #5 |
Quarry Creeper Join Date: Jan 2009 Location: El Cajon San Diego
I think it's telling you that you need to upgrade |
