04-06-2009, 03:55 AM | #1 |
Newbie Join Date: Jun 2008 Location: Tulsa
| quick disconnect for Novak Goat Brushless
I have a Goat brushless system and the wire connections between the motor and the ESC need to have a quick disconnect installed. What type of connection are others using? is there a specific type of connection that I should avoid? Thanks for the help
04-06-2009, 05:44 AM | #2 |
I used the Castle bullets on mine. Makes swapping motors out or taking things apart a breeze. Motor gets male end, ESC gets female.
04-06-2009, 09:48 AM | #3 |
Quarry Creeper Join Date: Jan 2009 Location: El Cajon San Diego
Castle bullet are the way to go. When I couldn't find them locally, I hacked up a couple Deans Ultra plugs.
04-07-2009, 05:14 AM | #4 |
Thanks for the reply, what size of the castle Bullit would be needed for the Goat brushless? I would love to order a couple of sets from HH but don't know the right size
04-07-2009, 07:48 AM | #5 |
4mm will suffice very well.
04-07-2009, 08:05 AM | #6 |
Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
I used regular 14g bullet/butt connectors.I peeled off the factory plastic insulation to get the size/diameter smaller,crimped them and added small amount of solder to the crimp area for sercurity and then they get some shrink tube.It's no big deal to just cut back the shrink tube and pull them apart if needed.
