04-08-2009, 01:24 AM | #1 |
Quarry Creeper Join Date: Nov 2008 Location: UK
| upping the voltage
I run a Sidewinder a 7T puller, DX3R, CCBec and 7995TG, 9.6v NiMh. Question, can I add another cell and run at 10.8v or am I going to start frying stuff?? |
04-08-2009, 01:50 AM | #2 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
The CC Sidewinder is good up to 12 cell Nimh. |
04-08-2009, 01:58 AM | #3 |
So I could run at 12 volts?
04-08-2009, 02:02 AM | #4 |
12cell nimh is 14.4 volts. You can run a 3s Lipo if you wanted. But you asked about 10.9v which is only 9cell nimh.
04-08-2009, 02:05 AM | #5 |
Apologies, I use 2/3A cells at 1.2v each, currently using 8no. so 9.6v If I use 10 cells obviously 12v. Just wondered if this would be ok? |
04-08-2009, 05:15 AM | #6 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i was using a 10 cell brick pack of 2/3 at 12.0 volts, but dropped down to 9.6 volts 8 cells to lower weight up high on the front axle the way i have my packs made...............bob .... |
04-08-2009, 07:38 AM | #7 |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
with the red wire mod and a CC BEC I'm running 4s A123 (13.2V) on my sidewinder WAAAHOOO, hello wheelspeed!!!
04-08-2009, 07:51 AM | #8 | |
http://www.castlecreations.com/products/sidewinder.html You can run 12 cells NiMH or 3S lipo....and those specs are listed for a 4600 motor.... | |
04-08-2009, 09:01 AM | #9 |
Thanks for the help, so when you talk about NiMh cells, you mean each cell is 1.2 volts.
04-08-2009, 09:17 AM | #10 |
Yes, each cell is 1.2V and if you run 12, then you would be at (12 x 1.2V = ) 14.4 Volts max.
04-22-2009, 01:04 PM | #11 |
Hey, I've just built up a 10 cell pack, charged it up and I am ready to have a go. Just a thought though, the overall voltage is now 14.4v, I was expecting to see around 12v, these cells must obviously hold more than 1.2v each. (marked up as 1.2v) Therefore a 12 cell pack would be too much?. (Still considering the switch to lipo) |
04-22-2009, 01:11 PM | #12 |
Rock Stacker Join Date: Oct 2004 Location: Concord
The spec sheet from Castle says 12 nimh for a 4600 brushless motor. You are using a brushed motor. So you should be just fine with your 10 cell nihm pack. I run a revolver black brusless motor from holmes hobbies with a 3 cell lipo with no issuses.
04-22-2009, 01:13 PM | #13 |
yes, I figured it would be ok, just couldnt understand where the 14.4v came from.
04-22-2009, 01:55 PM | #14 |
When I said I was good to go on the charging front, thought I was. Just checked still charging after 180mins at 0.5 amps, now up to 15v!!! whats going on? |
04-22-2009, 03:16 PM | #15 |
Fully charged now and dropped to 14.3v. Popped them in my rig..........woah!........ that 7t has really come to life!! |
04-22-2009, 03:48 PM | #16 |
Bump up the amps on the charging. When I was running an 8 cell nimh I was charging at 2 amps with no problem.
04-23-2009, 01:12 AM | #17 |
prefer to charge them slowly, nimh dont like heat when theyre charging
