04-08-2009, 02:27 AM | #1 |
Pebble Pounder Join Date: May 2008 Location: Vancouver, Canada
| How do I wire?
Hi, I am about to wire my first crawler and dont know exactly how everything goes. I have 2 esc an 8cell battery 1 cc bec and 2 servos. Can anyone give me a wiring diagram for this setup? Thank You for anyhelp. |
04-08-2009, 07:04 AM | #2 |
You'll need to provide a bit more information. What Rx/Tx system? How many motors? How are you wanting the servos to be controlled (seperately or combined on one channel)??? Are you trying to power both servos with that one CC BEC (not recommended)?? Wiring these setups is a mess, but is not too difficult. Here an old setup of mine that is similar to what you are wanting (the second ESC is on the opposing side of the one in the pic): |
04-08-2009, 11:55 AM | #3 |
I have a spektrum ar6200 rx and 2 motors, I guess ill pickup another bec. Your setup there looks to be the same as what im going for. I have a dx6 as my transmitter clod axels, 2 motors 2 servos for front and rear steering and 2 esc only 1 cc bec but ill pick up another if its not rec. to run both servos off 1 bec. Thanks for the help hopefully ill be running by next week. |
04-08-2009, 12:10 PM | #4 | |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
04-08-2009, 12:36 PM | #5 | |
I ran the battery lines and connected them with the battery lines from the rear ESC. Both positive and negative from the ESCs meet up and connect to one deans. For the rear ESC, I connected the motor leads. I then plugged the rear ESC into the port labeled "Rudder" on the Rx. Here's where my setup differs....for the rear servo, you would plug it into the port labeled "Aileron" on the Rx. You can then plug the BEC(s) into any remaining ports. I think I have mine plugged into the port labeled "Batt" on the Rx. You wire the BEC leads into the appropriate red and black wires coming from the ESC's that will eventually plug into the battery. For mixing options, here is the Tx manual, in case you dont have a copy: http://www.horizonhobby.com/ProdInfo...DX6_Maunal.pdf I hope this info is not too terribly comfusing.... BTW, in case you don't know, there is a vendor in the electronics section that is selling the equipment that you need to perform the left throttle return on your DX6. I made one for mine, but he's got a nice product. That Tx is much easier to control with this mod performed. Last edited by JeremyH; 04-08-2009 at 12:43 PM. | |
04-08-2009, 05:36 PM | #6 |
Thanks alot guys both of your help is greatly appreciated. Do I need to get another CC BEC or can I get by with the 1 I already have?
04-08-2009, 05:41 PM | #7 |
you only need the one.
04-08-2009, 05:44 PM | #8 |
Xirtic, Thanks that diagram is exactly what im looking for. |
04-08-2009, 05:51 PM | #9 |
Why do you use dig on that setup?
04-08-2009, 05:57 PM | #10 |
There are a few reasons: 1. I am using cheap Novak 55t machine wound motors....inherently these have a weak brake. Doing the switch dig does a short of the motor thus providing more of a lock. I am currently waiting on a pair of JP Customs Warrior II 45T handwound motors to get here, and I hope that they provide better braking. (I hear that they will) and this will allow me to remove the switches. 2. When mixing with the DX6 it has been documented that the rear does not like to lock without the switches...so I wanted the lock...so I have switches. Hopefully the new motors will allow me to ditch the switches. If not, this setup does allow for a ton of options as to axle locking, and independant axle control. |
04-08-2009, 06:00 PM | #11 |
Thats great info. Thanks again for all your info.
