04-11-2009, 04:05 PM | #1 |
Newbie Join Date: Apr 2009 Location: Asheville
| Glitching issue... Help
Guys I've got a AX10 that I just transfered over to a Copperhead Comp Chassis. I used all of the same electronics but for some reason it glitchs really bad and I've done all I know to do... Moved the ESC away From the Reciever, Used the plastic antenna holder to keep wire off of metal chassis.. Can you guys please help me out Im dying to do some crawling.. THANKS
04-12-2009, 06:44 PM | #2 |
Newbie Join Date: Jan 2009 Location: Frankfort
| Upgrade electronics
If your using the Axial electronics, trash them! I had the same issue and I upgraded all the electronics. I'm running the Novak Rooster Crawler ESC, 7 cell saddle pack battery, 45T Integy motor and a Spektrum radio. Now my crawler works perfectly with ZERO glitching. It will cost some $$$, but it will be one of the best upgrades you will make!
04-12-2009, 07:03 PM | #3 |
Quarry Creeper Join Date: Dec 2008 Location: other side of the track,the bad side
sometimes if you twist the leads from your esc to you motor you can reduce the uhf wavesand how are the batteries in you tx |
04-12-2009, 07:39 PM | #4 |
Newbie Join Date: Jul 2008 Location: Beaumont
The only thing to do is take it out of the new riig and test it. If it does not do it then there is something in the rig causing inf. When you put it back in the rig make sure there are not any power wires near the servo wires and make sure any metal to metal contact is tight.
09-16-2021, 11:56 AM | #5 | |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
| Re: Glitching issue... Help Quote:
09-16-2021, 12:08 PM | #6 |
| Re: Glitching issue... Help Given that this guy asked his question in 2009, and the last time he logged in was in 2016, it is doubtful you will get a response. But, if you are having the same issue, recommend following some of the advise above. Knowing what other electronics you are running would help to pinpoint the issue.
09-16-2021, 12:12 PM | #7 | |
The more I look for answer about my issues with that ESC the more people I find having the same problem. | |
09-16-2021, 12:13 PM | #8 | |
09-16-2021, 03:07 PM | #9 |
Rock Crawler Join Date: Dec 2005 Location: Marietta
I haven't had any problems with my Copperhead. Have you reached out to Castle support?
09-16-2021, 07:19 PM | #10 | |
I have a comp Saturday so I but my SW4 back in. I will run it more next week. I have found others that are having issues. | |
