10-14-2005, 03:38 PM | #1 |
Quarry Creeper Join Date: Aug 2005 Location: classified
| BEC set up question
I have this reciever to use with a Duratrax esc and they are both BEC. With both of them having BEC, how should I set this up? Do I use the 4-AA pack that I have for the reciever? What about the on/off switches? I have never had an esc w/ BEC before so I'm a little confused. Duratrax Intellispeed Auto-Sport Foward/Reverse Esc |
10-14-2005, 03:44 PM | #2 |
Quarry Creeper Join Date: Aug 2005 Location: Redding, True Nor-Cal, look on a map
What type of crawler are you putting it into? It only has 1amp BEC, so if you want to run 4WS you will need to run a RX pack. Otherwise, hook up everything, without the RX pack and you should be fine. Never mind, I just noticed that the reciever is only 2ch. Just hook it up without the RX pack and everything should run OK. |
10-14-2005, 03:49 PM | #3 | |
Trailerguy, thanks for the quick reply. Is the 4-AA thing a RX pack? | |
10-14-2005, 04:05 PM | #4 | |
10-14-2005, 04:13 PM | #5 | |
10-14-2005, 08:38 PM | #6 |
Quarry Creeper Join Date: Aug 2005 Location: San Juan Bautista
I have the 16t intelapeak and i run with a battery pack and the SC on at the same time.
