04-22-2009, 12:58 AM | #1 |
Quarry Creeper Join Date: Oct 2008 Location: Southern Illinois
| Servo without BEC
I'm fixing to add a JR9110t servo to my axial, with CC Sidewinder, and 3S lipo for battery. My motor is only a 55t. I also have a CC BEC which I have yet to install. My question is what would happen if I wanted to see how strong this servo is without installing the BEC? Will it smoke my ESC? or Will it just operate at a < 6v rate?
04-22-2009, 04:39 AM | #2 |
Quarry Creeper Join Date: Nov 2007 Location: NH
the sidewider has a rather weak BEC and it may shut down the esc when your trying to turn your tires under a load. It won't smoke it but it might not work while trying to steer. Just take the ten minutes it takes to install the castle bec and be done with it.
04-22-2009, 06:23 AM | #3 | |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
And it is not the voltage you have to worry about, it is the terribly weak amperage that the internal bec supplies. The higher the input voltage, the lower the amperage output. | |
