04-22-2009, 04:49 PM | #1 |
| esc getting HOT!
i have the axial esc that came with my rtr and ive one a ton of mods to my truck along with dig i check the temp after every run i noticed last run with my 1800mah pack that it got extremly hotter than normal and i ran normaly any ideas on whats going on??
04-22-2009, 04:59 PM | #2 |
Rock Crawler Join Date: Mar 2008 Location: ...in your meter box...
Did you run the same battery pack as before? Was it hotter outside today? Check your gear mesh to make sure its not too tight. |
04-22-2009, 05:39 PM | #3 |
| same pack ive lways ran, gear mesh is fine. warmer its like 5-7 degrees warmer but the esc and motor seam wayy hotter than normal and its only like 30 mins of run almost too hot to touch!
04-23-2009, 12:32 AM | #4 |
Damn, I was hoping for the simple solution. Does it get hot at idle or only after you've ran it a while? Make sure you don't have any wires touching at the ESC solder posts. Try a different battery. |
04-23-2009, 03:10 PM | #5 |
ill have to check the idle thing
04-23-2009, 03:45 PM | #6 |
yup it gets hot at idle with in about 2 minutes its warm and this was also with a diffrent battery could it be that its got 2 servos going and no bec? i checked every spot and not touching wires or anything the wire to the reciver also get warm but not hot. i have a small brushless fan sould i put it on the esc? if so how should i run seprate power to it (it can hanle 12v)? Last edited by 2500hdon37s; 04-24-2009 at 02:58 PM. |
