Thread: Servo Question
Old 05-01-2009, 12:10 PM   #1
Default Servo Question
Okay so recently I reset all of my electronics (fxr and dx3r). And now I do not have as much turning radius as before. Before my tires could easily hit my shocks now they are a good 1/4" from touching. So first question would be, when you first turn on your esc the point at which your servo goes to is that 0? So when I turn on the truck the servo does it's thing, then when I turn on my radio it goes to 0. Now I have not adjusted my trim on the radio at all! I just simple turned on the esc then turned on the radio and then put the servo horn on. So I tried doing it the opposite way too. Turned on the esc put the servo horn on and then turned on the tx. So when I went to trim it this way I did not eve have enough adj. to get it to 0. I don't know kind of at a loss right now on what I am suppose to do, any advice would be great. TIA!
Q
Drvnbeing is offline   Reply With Quote
Old 05-01-2009, 12:15 PM   #2
Latest NorCalRCRC slave
gunnar's Avatar
Shouldn't the transmitter be turned on first?
gunnar is offline   Reply With Quote
Old 05-01-2009, 12:26 PM   #3
Yeah your right. So when the tx is turned on first then the esc is the point that the servo goes to 0?
Old 05-01-2009, 12:40 PM   #4
So I have really got to stop being such a tard! So figured out how to adjust my throw, derr!! Anyways just want to confirm at what point the servo is at 0 if anyone can chime in on this it would be appreciated.
Old 05-01-2009, 01:01 PM   #5
gunnar's Avatar
If you turn on the radio, and set the servo trim to the middle(which should be your "zero" that you are refering to) it should be centered. If the servo horn is off to one side, then take it off and center it on the splined shaft. Then you can adjust throws/travel. Hope that helps.
