05-09-2009, 02:59 PM | #1 |
Quarry Creeper Join Date: May 2006 Location: Taylorsville
| killed 3 servos....now what?
ok..so i had a cheap futaba servo that stripped 15 min into crawling then i got a cys 200oz one from crawford and it died on me due to a loose connection internally, which crawford happily replaced no questions asked....but now i've killed the replacement that sent me. i was running a tq2 and the crawford one worked AWESOME...loved it..but now i have a 3pm, and apparently i need a digital servo instead of an analog... so, which one?!?!? i looked at the hs5645mg...but i hear it tends to strip a gear, so that's not good for $50 a buddy runs some ckrc wiggles...and says they're digital, but he also thought an hs645mg was digital...so are they? are there any other super budget 200oz+ servos that are digital???? |
05-09-2009, 03:20 PM | #2 |
RCC Addict Join Date: Nov 2008 Location: Greece, sun, sea and rocks
I cannot say for sure but I use a TowerPro 995MG with my DX3R at 5.5ms with no problem. Supposedly only digi servos work at that latency.
05-09-2009, 03:28 PM | #3 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
You should just spend the money on a 400oz servo and be done. You have seen what $50 gets you. Hassle, headache, and burned up servos.
05-09-2009, 03:30 PM | #4 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
I don't see why you would have to use a digital servo... can't use you just change the frame rate on your radio?
05-09-2009, 08:10 PM | #5 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
I would also suggest you pony up for a good servo and be done with it. Make sure to set the endpoints.
05-09-2009, 08:20 PM | #6 |
Rock Crawler Join Date: Apr 2008 Location: Highlands Ranch, Co.
This one is fairly cheap, cost a arm but not the leg: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNRN6 |
05-10-2009, 11:15 AM | #7 |
i really have NO IDEA about teh electronics aspect of rc stuff. i have nothing but electronic issues with ALL my cars haha but, i want a good servo...so, what's a good one under/around $100? |
05-10-2009, 12:19 PM | #8 | |
Rock Stacker Join Date: Apr 2009 Location: San Jose
~petev | |
05-10-2009, 12:47 PM | #9 | |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
3PM radios have EPA settings that most servo's can understand. Setting the EPA correctly can prevent a lot of undue stress on a servo. Without it, the servo is always trying to move further then your steering mechanics allow, burning them up quickly. Good Hitec and JR servos (300 oz plus) can go a long way and take a beating. I went through a couple TowerPro's in the beginning. You get what you pay for with them. I have not gone that route yet. I found a way to package a $30 1/4 scale servo (HUGE) on my BMV and have not stripped the nylon (yes nylon) gears yet. Even running modified 5.8" Claws. | |
05-10-2009, 01:10 PM | #10 |
Pebble Pounder Join Date: Dec 2008 Location: California
| both tcs and stormer have the 7955 for $100. when i was looking for a servo for my scx, the choice basically came down to $140 for an jr 8711 or $100 for the 7955. futaba and airtronics both make servos that have more torque than the jr 8711 for about the same price ($140), but i couldn't find anybody that had them in stock.
05-10-2009, 09:15 PM | #11 |
well...i read online that HRS mode will kill analog servos and i should be in PPM....but, i have NO clue what that means..or 90% of the other crap on my radio haha so a 7955 or the cs170? i keep hearing mixed reviews on hitech servo's...which is why i haven't really looked into them |
05-10-2009, 09:18 PM | #12 |
would getting a BEC help out the servo's being stronger as well?
05-10-2009, 09:32 PM | #13 |
Pebble Pounder Join Date: Apr 2008 Location: greenville
you need to read the manual it tells you how to change it out of hrs mode which is the reason your frying the analog servos
05-10-2009, 09:32 PM | #14 |
Rock Stacker Join Date: Mar 2009 Location: Angeles City, Philippines
depending on the servo... I guess... some servo will work only a certain voltage range... some will have the maximum power/torque at a certain voltage... so if that is the servo that you have then a BEC might help you out. in my own case, my servo won't run unless it is 6v or lower (4.8v)... so I need to power it with a 6volt power to maximize the torque... so i made my own 6volt voltage regulator |
05-10-2009, 10:47 PM | #15 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
| depends, if your ESC doesn't put out 6v or is low on amperage a BEC will improve your steering power no doubt, if it does and you have no issues with amping out then I wouldn't bother with the BEC, but since you seem to be rather budget minded I'm guessing you ESC doesn't have the best BEC. just remeber to disable the BEC in the ESC or you can fry the BEC in either or both the ECS and BEC.
05-11-2009, 08:12 AM | #16 | |
While holding down the SEL button, turn the Tx on. This will take you into PP - Sys Press SEL screen = Copy Press SEL screen = Clr Press SEL screen = Name Press SEL screen = HRS/PPM http://manuals.hobbico.com/fut/3pm-fm-fs-manual.pdf | |
05-11-2009, 03:58 PM | #17 | |
05-12-2009, 04:01 PM | #18 |
i got it in ppm mode.... now i gotta pick one of the 4,000,500 suggest servos out haha |
05-12-2009, 08:28 PM | #19 |
so....being as cheap as i am right now (building a slash, building a pede, building this crawler, trying to start a sc10 build) i just went with a hobbico cs150 $44.99 shipped off tower...193oz@6v and it's digital....metal gear, dual ball bearing...blah blah
05-12-2009, 08:44 PM | #20 |
Newbie Join Date: May 2009 Location: palmer
i had a hobbico and i blew it up but thats cause i drownded it for a good solid 2 mins so as long as ur not goin swimming with it u should be all set i did pick up a hitec 645mg and its not bad but its deff slower than the hobbico but i had rc madness send it out for me so now ill have a hitec for a spare
