05-10-2009, 01:14 AM | #1 |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
| Lipo Voltage
I have some 11.4v 1500 mah 25c Lipos and I just finished charging them after using them today. I always check to see what the voltage it finished at and one Lipo it was: 1. 4.20 2. 4.20 3. 4.19 The second Lipo was: 1. 4.19 2. 4.20 3. 4.19 Is this normal. If the cells had a charge still would that account for the .01 that is not showing. Just want to make sure the cells are not dying . Sorry about the newb Lipo question |
05-10-2009, 01:21 AM | #2 |
Rock Crawler Join Date: Sep 2008 Location: Delta B.C.
your fine, are you useing a balancer..i tested all my batts the other day and they all were the same voltage or off by .01 or .02 and i balance every few charges so i dont think 1 or 2 hundredths of a volt is too bad at all
05-10-2009, 01:26 AM | #3 | |
That's what I was thinking. As long as you have them hooked up to the balancer the charger balance charges them correct. Just an FYI it is a Venom Charger | |
