05-12-2009, 10:29 PM | #1 |
Newbie Join Date: Apr 2009 Location: BATON ROUGE
| 15c 20c 30c
i am running a traxxas velineon in my slash i am running a TrueRC 5000mAh 11.1V 3S1P 15C Pack now my issue when i go full Throttle the esc goes into lipo cut off i know the esc is functioning correctly (by way of A vom) my question is since my bat is a 15c is the velineon drawing to much current for my bat or am i way off base |
05-13-2009, 04:33 AM | #2 |
Quarry Creeper Join Date: Oct 2008 Location: In the basement...
You are not off base the batteries aren't up to the job and are dropping a lot under load - get some 25c and you should be fine
05-13-2009, 07:19 AM | #3 |
Rock Stacker Join Date: Aug 2007 Location: Bonn, Germany
Right, 15C is not enough. I run a kokam 2s 5000mah 30c in my slash vxl, works great. 25c should be enough. If you have the choice, I would recommend you to buy 3s! I drove a friends slash with that, incredible... but depends on how much power you want/need.
05-13-2009, 04:44 PM | #4 |
Rock Stacker Join Date: Aug 2008 Location: BC Canada
yes 3s 30/60C 5000mah w/ brushless on a slash is very good. Just avoid a CC 5700. You will burn that up too fast. The velinion is supposed to be good though.
05-15-2009, 07:07 PM | #5 |
RCC Addict Join Date: Jun 2008 Location: Fresno
15c? might as well go with a nimh pack. w/ such a low c rating you're really not getting the full benefits of going lipo
05-15-2009, 07:21 PM | #6 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
| I have a CC 5700KV and a 3S lipo, 25C, the only thing I burn up is the asphalt or dirt....runs a little warm but not to hot to touch...where do you get your info??? I have read alot of people that run the 5700KV on 3S and love it......
05-16-2009, 10:47 AM | #7 |
RCC Addict Join Date: Mar 2008 Location: SSF
Alot of people don't know how to figure out the amp output of a lipo battery but it's really simple. 1000Mah by 10c = 10 amp output simplified 1000 Mili amp hours = 1.0 amp hours 1 amp hour by 10c = 10 amp output 2000Mah by 10c = 20 amp output 3000Mah by 10c = 30 amp output In my Slash and SC10 I have three Lipos, spec'ed like this. MaxAmps 8000Mah, 3s, 20c = 160 amps MaxAmps 8000Mah, 2s, 20c = 160 amps SMC 5200Mah, 2s, 28c = 145 amps Freak's TrueRC 5000mAh 11.1V 3S1P 15C Pack = 75 amps. Not very good for a Vellineon motor, those motors are very hungry. |
