Thread: Motor Turns
Old 05-21-2009, 10:07 AM   #1
Default Motor Turns
I need a new motor :-(, my 65T has lots of torque, but even with an 18t pinion, my axial is still slow. I'm looking at going to a 35 or 45 turn motor (no, not ready to go brushless yet and my rooster crawler would likely fry under a 11.1v lipo, only rated to 8.4v) and I was wondering what the RPM difference is between the different motors. For instance, at 5vdc, what the motor RPM would be for a 65T, 55T, 45T, and 35T?
Greatscott is offline   Reply With Quote
Old 05-21-2009, 11:30 AM   #2
Directly from Holmes' website:
Motor speeds (taken from random and averaged sample @ zero timing & 3100rpm):
10t = 6526 rpm/volt
15t = 4317 rpm/volt
17t = 3753 rpm/volt
20t = 3216 rpm/volt
21t = 3082 rpm/volt
23t = 2790 rpm/volt
25t = 2588 rpm/volt
35t = 1565 rpm/volt
45t = 1210 rpm/volt
55t = 987 rpm/volt
65t = 837 rpm/volt
JeremyH is offline   Reply With Quote
Old 05-21-2009, 12:29 PM   #3
You sir, ARE THE POO!!!
Thanks a lot for the info!!!
10t = 6526 rpm/volt
15t = 4317 rpm/volt
17t = 3753 rpm/volt
20t = 3216 rpm/volt
21t = 3082 rpm/volt
23t = 2790 rpm/volt
25t = 2588 rpm/volt
35t = 1565 rpm/volt
45t = 1210 rpm/volt
55t = 987 rpm/volt
65t = 837 rpm/volt
Old 05-21-2009, 12:46 PM   #4
No problem.
Glad to help.
Old 05-21-2009, 12:50 PM   #5
those motors kick ssa! I have his 30turn and it kicks ssa! just enough wheel speed, and plenty of torque!
they might be a bit more but man they sure are purdy!
nmanuel01 is offline   Reply With Quote
Old 05-22-2009, 10:50 AM   #6
i'm running a 55t with 17/87 gears and i'm finding myself turning down my throttle travel cause i had to much wheel speed....then i adjusted it up till i had the wheel speed that suites me...........bob
bob1961 is offline   Reply With Quote
Old 05-22-2009, 09:02 PM   #7
i am running the 55T Rooster combo w/ a 2s 2200 lipo geared 87/14
it has plenty of torque and wheelspeed for me....i was running a 6C 1500 NIMH saddle pack and the difference is like night and day
NCcrawler is offline   Reply With Quote
