06-07-2009, 07:41 AM | #1 |
Newbie Join Date: May 2009 Location: UK
| Glitching Novak Goat
Does anyone have a cure for a Novak Goat (brushless) that glitches when going into reverse? I've tried the following to fix the problem, but no luck so far.
The glitch/jump happens when the red LED goes out on the esc The problem is more noticeable when try in to creep at low speed Using Futaba 2.4ghz radio Best Regards Mike |
06-07-2009, 08:10 AM | #2 |
Newbie Join Date: Feb 2008 Location: Connecticut
Have you tried adjusting the dead band on the esc?
06-07-2009, 08:38 AM | #3 |
06-07-2009, 10:57 AM | #4 |
Newbie Join Date: Oct 2008 Location: Philippines
Maybe you could try this http://www.mtroniks.net/details1.asp...sid/27/ZGM.htm ZGM Zero GLitch Module might eliminate the problem or the use of castle bec? |
06-07-2009, 08:39 PM | #5 |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
This is what you might need.. Novak Glitch Buster: http://www.shopatron.com/product/pro...=NOV5626/135.0 |
06-08-2009, 01:25 AM | #6 |
Thanks for you help, I think I may hit the nail on the head and fit opto isolators and the novak glitch buster together lol Best Regards Mike |
