06-12-2009, 06:06 AM | #1 |
Quarry Creeper Join Date: Apr 2006 Location: GUAM
| help! HH crawl master motor
ok here's what im running: sidewinder with a crawl master motor 1000kv and 2c 4000hv pack from max amps. heres the problem,motor works but when im trying to crawl my rig the motor hesitates to turn but when i give it more throttle thats when it will spin but the amount of throttle i give it to spin is more than what i need. any help |
06-12-2009, 06:13 AM | #2 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
thats one of the draw backs to outrunners. They cog more and need more current to get them moving initially.
06-12-2009, 06:16 AM | #3 |
| motor
could it be my plugs? cause i got the esc second hand and the motor and the esc had a diff. bullet plugs on them so i switched out the motors o.g. plugs to match the esc and there are a little smaller than the original. |
06-12-2009, 06:29 AM | #4 |
Quarry Creeper Join Date: Sep 2007 Location: Central Coast, NSW, Australia
Shouldn't be the plugs. As mentioned, outrunner motors need a bit of extra juice to get them to start up from stopped. Once they are spinning they're fine. Not much can be done other than reducing the gearing. EDIT- you could try checking the timing on the Sidewinder programming, but chances are its probably not the cause. Last edited by LincolnBlack; 06-12-2009 at 06:30 AM. Reason: thought of more to add |
06-12-2009, 06:32 AM | #5 |
| gearing
ive never had this problem befor im running all crawl master motors on all my rigs but ill give it a shot and gear down,im using a 16t pinion on a r2 trans. guess ill start from a 9t pinion and work my way up. thanks for the info |
06-12-2009, 06:42 AM | #6 |
Go into the Castle Link. Put your start up power on high,if it's not there now,that should help some. Play with your throttle curves a little. Put them on the "curve" setting and adjust them. That can make a big difference....allot of trial and error,but it can help allot. Gear down,volt up. That'll make a big difference. I ran a 850kv Crawlmaster on a R2 back in the day....on an 8 cell pack with an 18t pinion. Pretty good performance. I would imagine a 12-14t pinion would be pretty good if you ran a 3 cell lipo. Not a ton of wheelspeed,but it'd probably do pretty good. The R2's are geared REALLY low anyway,so that is helping you. |
