06-17-2009, 11:26 PM | #1 |
Quarry Creeper Join Date: Apr 2008 Location: Clay, Alabama
| V11 35T worth the extra money?
Are the V11 35 turn motors worth the extra money over a "normal" 35 turn? It would be going in a Losi Comp Crawler, running on 3 cells from a Tekin FX-R.
06-17-2009, 11:36 PM | #2 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
I am not sure a 35t motor would be the best bet in that application. I would look at a handwound motor, and if thats to expensive, go with the cheaper one with the intention to upgrade later.
06-17-2009, 11:42 PM | #3 | |
Pebble Pounder Join Date: Apr 2009 Location: between a rock and a hard place.....
06-18-2009, 07:24 AM | #4 |
From what I've been reading it sounds like a brushed motors of any wind aren't really hitting the mark with the Losi Crawler. I personally would go with the Losi 21.5 brushless when available. If you have a lathe and dyno you can usually make a cheaper motor run pretty well if you don't your better off with the higher priced hand wound motor the less expensive motors usually need some work. |
06-18-2009, 07:28 AM | #5 |
I hear the brushed motors run really hot as well. A traxxas titan 550 may be the best bet to get you going with a brushed motor. Anything that is larger than a normal 540 so it has more can to dissipate heat.
06-18-2009, 10:04 AM | #6 |
This is probably going to be a stepping stone while I wait on $$$ to go brushless (unless I find a brushed motor that makes me happy). I currently have a Johnson silver can motor from a Tamiya kit in it, and I'm actually very happy with the way it performs - until I realized the FXR on 3 cells doesn't like lower turns than 35. Now I'm looking for something that fits the spec of the ESC. I figure I'll need to put a heat sink/fan on it, and that would be OK.
