06-30-2009, 11:33 AM | #1 |
Pebble Pounder Join Date: Oct 2008 Location: Belcamp
| lathe motor
is there a difference between my novak 45t motor and a lathe motor? thanks guys |
06-30-2009, 11:41 AM | #2 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
06-30-2009, 11:44 AM | #3 |
ok cool, so my novak 45t is a lathe motor?
06-30-2009, 11:52 AM | #4 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
What are you considering a lathe motor? Most motors back in the day were 21 turns and lower that was used for bashing and racing. The reason for that is well, there were not any rock crawlers around then. The only need for the high torque motors were the little comp lathe's and brush cutters. The com lathes needed a slower, high torque motor. So there were a few companies that made "lathe" motors. Most of them were 55 or 65 turns. This was done to keep the RPM's down and have the torque not to bog when you started cutting the com. From what I know, this is the reason we have "lathe" motors. When we got the crawlers, we need all the torque we could get so we started using the lathe motors. I still remember them being hard to find in 05 or 06. Someone correct me if I am wrong. |
06-30-2009, 12:05 PM | #5 | |
Quarry Creeper Join Date: May 2007 Location: Euless Tx
06-30-2009, 12:39 PM | #6 |
perfect i understand now |
06-30-2009, 05:42 PM | #7 |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
08-06-2009, 06:11 AM | #8 |
Pebble Pounder Join Date: Jun 2009 Location: Jackson
So lathe is just a term? And a 35t regular motor and a 35t "lathe" motor turn the same rpm/volt? |
08-06-2009, 08:03 AM | #9 |
| When your talking about machine wound they are all really close. There are a lot of variables in a motor though. The size of the com, the strength of the magnets, the brush configuration. All of those are factors in a brushed motors performance. But for the most part, most machine wound crawler motors are really close to the same. Its when you get into handwounds that everything changes. |
08-06-2009, 08:28 AM | #10 |
Yep, lathe motor is just a term that was used for the origional 55t motors we would buy from motor lathes.
08-06-2009, 08:33 AM | #11 |
Quarry Creeper Join Date: Jul 2008 Location: peoria
who sells hand wound motors or can you make one your self
08-06-2009, 08:48 AM | #12 |
| I would leave motor winding to the professionals. As for who sells them. There are several vendors out there. Holmes Hobbies, JP Customs, Brood, Banzai, and Tekin. I am sure I have left some one out but its a damn good start. |
