07-05-2009, 03:57 PM | #1 |
WOOPOOW!! Join Date: Nov 2008 Location: Atlanta, GA
| Nomadio React Setup. Veterans please help
Just got this off of SVEN today, and after plugging it into the computer, i have no idea what Im doing. Could you guys help me set it up? I just got rid of my DX3, and this is a heck of a sight different than that freaking thing. Any help, tips, or tricks are greatly appreatiated |
07-05-2009, 04:11 PM | #2 |
Just mess around with the different settings for different buttons. Here is a setup for one esc and elec dig. I run those settings on my super and berg. Down the page a bit. React button programing question... |
07-05-2009, 04:12 PM | #3 |
Pebble Pounder Join Date: Apr 2008 Location: Indiana
You'll need to download the React desktop software from Nomadio.net The radio is almost limitless on the set-up, mixing, and switch selection. I prefer the Sensor for the larger screen and different feel, but I also have the React I use for carpet racing and backup crawler. Post what it is your trying to set-up and I'll try to help. |
07-05-2009, 04:44 PM | #4 |
Im trying to set it up for 3pos. 3rd channel switch for my Berg. It will be bound to a sr3000 receiver.
07-05-2009, 04:46 PM | #5 |
See above link i posted above ^^^^. All the settings are listed in that thread.
07-05-2009, 04:50 PM | #6 |
07-05-2009, 05:21 PM | #7 |
So, shane, in that thread you say you are running dig switches and all. I do not have dig switches. I am running the PunkRC dig |
07-05-2009, 06:41 PM | #8 |
So I just found out i have to change it to DSSS Beta to run my speky receiver. Everytime i try to send the update to my tx i have to upload stupid arse firmwire and it WILL NOT download... what am I doing wrong.. I know my radio isnt messed up..
07-05-2009, 10:46 PM | #9 |
Is this thing on? Anyone? anyone at all know whats going on? It wont connect to the transeiver or anything... |
07-06-2009, 01:38 AM | #10 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
Think I had that problem to, not sure what I did. might have just updated the the firmware first then started messing with settings later or rebooted it? Did you register it also? |
07-06-2009, 02:58 AM | #11 |
Yep, its registered and ive updated the software to 3.2 beta. Still wont send the firmware to my transeiver.
07-06-2009, 04:01 AM | #12 |
RCC Addict Join Date: Jul 2008 Location: Sin City
Not that it gets much attention anymore but nomadio has a forum where most of this stuff im sure has been run through if you cant get the answer you need. Im happy to help you with all your setting questions but i run a Sensor so i only run the Nomadio transievers.
07-06-2009, 04:52 AM | #13 |
Firmware to the RX....are you trying to send firmware to a Spectrum Rx? If so give up it ain't happening nor needed. If you sending it to a Nomadio Rx but runing a Spectrum then again give up it don't matter and really isn't necessary. That said I've had occasional Radio/Rx update problems, make sure your plugged in to the Rx port marked digital and the arrow on the plug goes toward the inside of the slot. You can as posted above pose the question on the Nomadio forum www.support.nomadio.net (I think?) or call direct for faster response 215-854-8432 ext. 202 or 0 and ask the operator to page Scott |
07-06-2009, 08:23 AM | #14 |
Im trying to bind the Nomadio to my spektrum sr3000. So I have to set it to digital? I cant plug the rx into anything? the plug in the controler is too big!
07-06-2009, 08:32 AM | #15 |
I dont have any experience binding spektrums to reacts. Look in the "React Only" section and search around. try this link. http://support.nomadio.net/ |
07-06-2009, 09:13 AM | #16 |
I searched around and found someone says this: Select -- Menu -- Advance -- Tranceiver -- DSSS Beta (this will allow you to use the spektrum receivers) I did that, but it wont send the settings to my transeiver/transmitter! It keeps telling me I have to upgrade firmware before I can send new settings, but it wont update!!! It just restarts the update question... |
07-06-2009, 09:22 AM | #17 |
Looky here. I found this on like page 5 of searching "nomadio react". And i actually helped fix the problem (maybe). I knew I had heard of your issue before. And it was SVEN that had the issue! Hope it can help you out. React is 'searching' http://support.nomadio.net/viewtopic...ight=searching |
07-06-2009, 09:40 AM | #18 |
I'm not that far yet. I cannot even download settings onto my nomadio anymore. It says: You must update firmware on your react before you send anymore settings. Would you like to update now? So I say yes. Then it says: Installing firmware (the little bar loads up) Then it says: Rebooting react (the bar loads up) Then it says installing again (Little bar loads up) Then it says: You must update firmware on your react before you can send anymore settings. Would you like to update now? thats ALL I get.. and NO settings are sent... |
07-06-2009, 09:59 AM | #19 | |
Keep searching on the Nomadio forums. Saw some things about a Vista plugin you need (if you are running vista). Saw some things about low batteries. Searching firmware. It's probably something super simple. I would send Nomadio an email stating what you said above. I had one or two day response time with them. | |
07-06-2009, 10:08 AM | #20 | |
