11-07-2005, 02:55 PM | #1 |
| Pirana Charger ?'s and times?
OK, I just got one of the digital pirana chargers for my battery packs. It has a ton of settings and a lcd screen readout. My ? is this, what is everyone running for charges? What I mean is , there are like 50 different settings and the instructions are very vague. I have 6 cell 3300 nimh packs and I also have the 6 cell 1100 nimh packs, how long and how many amps are you guys charging? Are you doing full discharge before the nextv re-charge? Sorry, I just don't want to fry my new packs and chargers and want to get the most run time I can.
11-07-2005, 04:36 PM | #2 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
Since you are wanting runtime you will want to charge at a lower amp setting. A general rule of thumb for amp setting is to double the # of mah. Like a 2000 mah pack would be set at 4 amps, A 1000 mah pack would be set at 2 amps, etc. If you want more punch, then you would go a little higher (.5-1 amp) and if you want more runtime go a little lower. I think the highest amp setting for the digital pirana is 5 amps, so you won't be able to hurt that 3300 pack, just don't overdo it with the 1100 pack. |
11-07-2005, 04:39 PM | #3 | |
11-07-2005, 05:50 PM | #4 |
Rock Crawler Join Date: May 2004 Location: Calgary
I personally charge all my 3300mah packs at 3 amps. Provides good runtimes, and keeps the packs uber-safe. Charge rate will also be dependent on the size of the cell, and the quality. Smaller cells like 2/3A shouldn't be pushed to hard. I find 1 Amp is plenty for charging GP1100 cells. As for discharging, yes it's always a good idea to discharge a pack before recharging it. Helps out with both the batteries capacity and with its lifespan. |
11-08-2005, 02:20 PM | #5 |
Quarry Creeper Join Date: Jul 2005 Location: Oran, MO
I have the digital pirahna charger you speak of. I love it. Never had a false peak. Just remember you have to have it on DC power to get 5 amps out of it. On AC power it will only charge at 3 amps. For runtime I would charge your 3300 at the auto setting. It varies the charge amperage to kind a revitalize your cells. Of course if you want it to charge faster increase the amps. When I was racing I would charge my 3300's at 5 amps and it would get done in 45 minutes.
