07-10-2009, 07:11 PM | #1 |
RCC Addict Join Date: Oct 2008 Location: PA
| Jittery Axial - Please Help
The specs- Axial RTC with Rooster Crawler, factory Axial 55T motor with 3 Novak capacitors, factory servo (AS-2), factory reciever. The problem- After running at full throttle in foward, if I go in reverse a little while later, it does some kind of glitchy/jittery start stop start stop thing. It will also just quit (untill I pick it up and it comes to life again) when it's in a "not really" bound up position. I little while ago I made my standard 6 cell battery packs into a saddle pack setups by soldering, then taped them together like a brick. I ran both batteries all the way down on my last outing. Could that be a cause? Or is it something else. I redid the reciever to ESC programming and it still does it. Thanks in advance for the help! Here are the pics of my setup: |
07-11-2009, 05:51 AM | #2 |
Any thoaghts guys? Just want an opinion before I go buying more batteries.
07-11-2009, 09:03 AM | #3 |
RCC Addict Join Date: Oct 2008 Location: Plainfield, IL.
I doubt its your battery, personally i keep my esc and reciever away from eachother because i was having problems with my old axial, so my hobby shop told me to keep them away from eachother and it helped a lot. I would also put deans connectors on your batteries and receiver just for shits and giggles.
07-11-2009, 09:17 AM | #4 |
Pebble Pounder Join Date: Oct 2008 Location: L.A. lower Arkansas
I would try moving the reciever and esc as well. I would also try a different motor just to be sure....
07-11-2009, 10:12 PM | #5 |
Played with it for 2 minutes tonight and moved the Receiver, that was my issue. Thanks guys!
