11-08-2005, 02:26 PM | #1 |
Quarry Creeper Join Date: Jul 2005 Location: Oran, MO
| Jr XR3
I was about to modify a TQ3 that I purchased off ebay for the independant rear steering. Then I remembered something in my Jr XR3 owners manual. It has a 3rd channel setting to the tamiya 3 speed transmission. I did some more reading last night and I think it will work for rear steering. It won't be any more proportional than the TQ3, but its already done and has EPA adjustments. From what the manual said it will be left-center-right or 1st-2nd-3rd. And it will stay in what ever position I set it in and return to center when I want it to. It will be easier to crab steer and I won't have to hold a button. Has anyone else used this radio with this setup?
11-08-2005, 02:33 PM | #2 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
The xr3 works great. The switch is a little hard on the back of my thumb.
11-08-2005, 02:48 PM | #3 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
I use the XR3 for rear steer, works great. The thumb rocker is self centering, so you will have to hold it left if you want it to stay left (same with the right position). There is a thread somewhere on here about how to change the 3 channel switch from the A rocker to the B rocker. You have to open up the radio and do a little soldering, but it makes using the rocker a lot easier. I'll try to find the thread.
11-08-2005, 03:15 PM | #4 |
Found it, go down to post #8 : anyone mod a jr xr3i?? |
11-08-2005, 11:05 PM | #5 |
Thanks for the tip SVEN, I just did the mod and it will be much easier to use now.
11-08-2005, 11:26 PM | #6 |
Quarry Creeper Join Date: Jan 2005 Location: In the Garage!
will the newer XR3i do this same thing. thanks
11-09-2005, 06:00 AM | #7 |
Quarry Creeper Join Date: Nov 2004 Location: MANVILLE
IF the switcks work the same as the xr3 it sould.the curcuit bourd that the switchs are mo0unted on has 5 wires.the black wire doesn't get moved.basicly what you are doing is placing the wires from 1 switch to the other
11-10-2005, 07:58 PM | #8 |
Newbie Join Date: Oct 2005 Location: USA
ALRIGHT, how are you guys making it go from left to center and then right? mine only goes left to right, there is no center with the switch? this is the JR XS3 we are talking about right? help me im confused |
11-10-2005, 08:03 PM | #9 |
No, JR XR3. It is the older model.
