07-13-2009, 02:28 AM | #1 |
Rock Crawler Join Date: Sep 2007 Location: Denmark
| Novak 4s LVC ?? Hi guys Simple question for you How do I connect 2 x2s1p LiPo's to a 4s LVC ? Do I use an adaptor between the 2 lipo's and the Novak 4s LVC ? |
07-13-2009, 02:40 AM | #2 |
Quarry Creeper Join Date: May 2008 Location: looking for sponsors
i guess you could just use the LVD to the esc wires and use a adapter between your 2 lipos to plug into the escs battery leads but i could be wrong i dont know how these LVD work |
07-13-2009, 06:02 AM | #3 |
Pebble Pounder Join Date: Oct 2008 Location: L.A. lower Arkansas
I built a adapter to hook the two batteries in series then hook the lvc to the adapter. positive to positive negative to negative of course.
07-13-2009, 09:12 AM | #4 |
Rock Crawler Join Date: Jul 2006 Location: Hobbywing
Novak LVC also plugs into the RX, then the ESC's RX Wires plug into the LVC. Then you have to do a basic "one touch setup" to the LVC. You LVC pickup wires should be on the red and black that go to the ESC, or just on the ESC plug itself to make it simple. |
07-14-2009, 03:15 PM | #5 | |
How do I connect the balance wires from two 2s lipo's to the 4s balance conector Do I wire the balance adaptor like this ? 4 single black wires and the 2 red wires in a "Y" I hope this makes sens :? | |
07-14-2009, 09:43 PM | #6 |
The Novak LVC does not connect to the balance plugs.
07-16-2009, 03:11 AM | #7 |
