11-08-2005, 05:39 PM | #1 |
Rock Stacker Join Date: Nov 2004 Location: Sherwood Forest - UK
| 4 servos off of 1 reciever
ok, i know 4 servos is bit over kill, but on my stupid big maxx truck i couldn't get just 2 to work. so, anyway, problem i've got is that sometimes i get lots of interferance now there's 4 plugged in, that i didn't get with 2. is there anything i can do to sort this? ps, i've linked them all together with y harnesses. thanks for the help guys. ps servos are hitec 5745 mg |
11-08-2005, 05:41 PM | #2 |
RCC Addict Join Date: Jan 2005 Location: Green River Kentucky
You need to run a reciver pack the glitching is caused by not having enough power.The factory bec cant power all 4 servo's.
11-08-2005, 06:08 PM | #3 |
Quarry Creeper Join Date: Oct 2005 Location: Bryant, AR
I just did a post about this, but it was with only 2 servos and I found that a reciever pack fixed the problem. I just cant find where it went, I didnt delete it because I thought it would be of some help to someone like yourself. I found it, for some reasion I thought I posted it in electonics, but it is in Newbie General. |
11-09-2005, 01:05 PM | #4 |
thanks for the quick replies guys, but...... i'm running a 6v reciever pack. have i done it right? i've just connected it to the red & black wires on the servos, then ditched the red wire on the feed from the esc (traxxas cvx) sorry to be a pain with such a dumbass question. |
11-09-2005, 01:45 PM | #5 | |
Pebble Pounder Join Date: Oct 2004 Location: Colorado
You need to make a custom Y-harness. Do not power four Servos through your Rx leads. The excess current draw will cause your Rx to “glitch”. Connect the red & black leads from your Rx battery directly to the servos. Do NOT connect the red wire from the Rx battery to your Rx or ESC. By the way, A voltage regulator is a better alternative than the Rx Battery. Last edited by BultacoJim; 11-09-2005 at 02:08 PM. | |
11-09-2005, 03:47 PM | #6 | |
i've modified the harness which connects all the servos together & links them to the rx. the esc has the red wire that goes to the rx dissconnected, but still has white & black connected to the rx. the rx battery pack is wired straight into the harness between the rx & servos. some1 told me to do it this way rather than to plug the batt into the rx & draw power through the rx all the servos are driven off of a single channel on the rx, not split for front & rear across two channels hope that makes more sense to u all. any ideas, or have i still got it wrong. | |
11-12-2005, 04:06 PM | #7 |
no more ideas anyone?
