| | #1 |
| Pebble Pounder Join Date: Oct 2008 Location: KY
| alright so im been thinking about starting a berg build and had a question the FXR and FXR-PRO can these esc's run dual motors and if so whats there limitations on turns would i be able to run two 35t on a fxr that has a 13t limit or would i need a pro with no turn limit let me know Thanks |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: Mar 2009 Location: Hartford
| You would be fine with just running the regular FXR. It will run the two 35ts without a problem. Unless you plan on making your berg a speed machine by getting motors lower then 13t that would require the Pro, just stick with the regular FXR for what you are needing out of it. |
| | #3 |
| Pebble Pounder Join Date: Apr 2008 Location: Fort Wayne
| The FXR-Pro is a little overkill for crawling. I run a single FXR and a PunkDig and have never had a problem running 2cell & 45t motors. I use a Castle BEC for good luck. The speedo would get warm runnng a 7995 servo (330 oz), the BEC cured that. |
| | #4 |
| I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
| I know lots of guys running the fxr on 3s with dual motors without problems. The pro will jut give ya alittle headroom if you are one of those belt and suspender guys. |
| | #5 |
| alright thanks guys i just bumed a 3s off a friend to see how much better the 3s was than a 2s thanks for the info |
| | #6 |
| I wanna be Dave ![]() Join Date: Jan 2004 Location: Detroit
| FX-R is fine...FX-R is overkill, but well fun. 3S you have to use a BEC...though its best to use one all the time. |
| Thread Tools | |
| Display Modes | |
