| | #1 |
| Quarry Creeper Join Date: Feb 2008 Location: Irvine KY
| Okay, I was out crawlin, and my wk took a fall. I was running without the body and it landed on the edge of a rock, motor first. Now I give it the gas, nothing, if I turn the wheels the motor clicks. Anyone had this problem, is there anything I can do to the motor to fix it? Thanks. |
| Sponsored Links | |
| | #2 |
| Dave's not here!!! ![]() Join Date: Jul 2005 Location: Silverdale, WA
| Is it the motor clicking, or is it the grub on your pinion making contact with the spur? I have noticed slop in my motor (same one) the older it gets and the rotor will move back and forth (about 1 -2 mm) when I go from fwd to rvs. I started to get clicking that took me a while to track down, finally I noticed the grub was contacting the pinion when I was in revse, or when I had a load on the motor, I'd check this first. |
| | #3 |
| Its the motor clicking, I took the spur off when I got in and turned the motor over by hand. But giving it the gas forwards reverse doesnt work at all. |
| | #4 |
| Rules? What Rules! ![]() Join Date: Apr 2008 Location: Tallahassee, Fl.
| You MAY have knocked a magnet loose. Take the motor apart & pull on the magnets with your fingers & see if one moves. |
| | #5 |
| Okay, thanks, I'll check it out. |
| | #6 |
| I fixed it. There was two magnets on the back side of the motor on the shaft, and the magnets had little tunnels that would allow them to move if needed, and one of those magntes was pulled completely out. |
| Thread Tools | |
| Display Modes | |
