| | #1 |
| Rock Crawler Join Date: Jul 2007 Location: Portland,OR
| I plan to run an FXR in my 1.9 scaler. I also plan to see a lot of water/mud. I'll probably do as I've done before and stick it in a balloon or seal it up in a box, but I'm wondering if it may have heat issues being sealed up. I'm not too heavy on the throttle, except on steep stuff, but I am running a 1320mah 3s Lipo owith a 45T. I debated sticking the tekin in the comper and using the comper's Mamba Max for the scaler. Never had a prob with heat with a BEC on the MM sealed up in my 2.2 scaler... but the Tekin's so tiny! I will be running a CC BEC as well and a seperate 2s for the winch (if that matters). Should I worry about heat? Don't want to 'de-solder' stuff! |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Dec 2008 Location: fairfield
| you should have no problems with it sealed in a balloon. mine runs cool never gets hot all. i'm building a scaler too and planning on submerging it so this is what i ordered. http://www.bgmicro.com/index.asp?Pag...D&ProdID=11968 it should fit my esc rx and bec with out a problem. it will fit perfectly between my frame rails to and hopefully look like a fuel cell when done |
| | #3 |
| Pebble Pounder Join Date: Jan 2008 Location: Carson
| wat about wires coming out of that? ull have to demel a slot and then seal that spot up. |
| | #4 |
| i figure something like this would work http://www3.towerhobbies.com/cgi-bin...?&I=LXMNK6&P=7 or something like these which can double as scale sfifter boots http://www3.towerhobbies.com/cgi-bin...?&I=LXMNK4&P=7 or you can just go old school water sealing. lol http://www3.towerhobbies.com/cgi-bin...?&I=LXMNK5&P=7 |
| | #5 |
| Rock Crawler Join Date: Jul 2008 Location: Port Angeles
| The black plastic "project boxes" from radio shack work very well and are pretty cheap. Cut a slot out for the wiring and seal it up using either dielctric grease or some silicone around the wiring and a bead between the lid and the box to act as a gasket. |
| | #6 |
| Yeah it probably won't get too warm with a BEC. If you don't want to go to Radio Shack, go to Fred Meyer or Safeway and pick up some plastic gerber baby food containers. they come 2 to a pack and will fit a Mamba Max and BEC and winch control unit perfectly. Just cut a hole in the lid foe the wires, seal it up with silicone and forget about it. My 2.2 scalerbeen running that way for a year now w/no need to reseal. So ya'll think it'll be OK sealed up on 3s then? |
| Thread Tools | |
| Display Modes | |
