Thread: Traxxas XL-10 Help...!
Old 07-17-2009, 10:23 PM   #1
Dave's not here!!!
Greatscott's Avatar
Unhappy Traxxas XL-10 Help...!
I have a little problem with my XL-10, the wires going to the RX have come unsoldered. I know generally where the three wires came from, but I have no idea which order they were soldered. If someone has a XL-10 (or even a XL-5) that they wouldn't mind popping open and take a picture so I can get the wires soldered back on in the correct order.
Thanks. This is a big setback on my X-Trail project...
Greatscott is offline   Reply With Quote
Old 07-18-2009, 01:37 PM   #2
From left to right black, red, white. This is looking at the XL5 board from the perspective of the cap being on the bottom of the board making the pads on the lower right corner of the pcb. Hope that helps...
ohmyCLOD! is offline   Reply With Quote
Old 07-19-2009, 12:31 PM   #3
Dave's not here!!!
Greatscott's Avatar
You're a god! Thanks! Soldering on to those tiny little posts was tricky, but got everything back together and it works like a charm.
