Thread: BEC wiring
Old 07-18-2009, 08:05 PM   #1
Default BEC wiring
I have a CC BEC wired to my CC Mamba Max. I followed the wiring provided by CC but it don't sense cause the way they instruct me to wire the truck will cause the truck to stay on at all times. What do you guys do?
Happy_trucker is offline   Reply With Quote
Old 07-18-2009, 08:25 PM   #2
On the lookout for Rocks
constantmotion's Avatar
Your servo will be powered on when the battery is plugged it. Most ppl always unplug the battery when they're not driving anyway, so that isn't a problem.
When you mention that it's don't sense, what exactly do you mean?
constantmotion is offline   Reply With Quote
Old 07-18-2009, 08:27 PM   #3
It will cause the Steer/Aux channels to stay on, but the Throt will still be controlled by the ESC switch.
Many folks just unplug the battery to PO/PO. Actually, many jump-out/bypass the ESC power switch, in which unplugging is the only means to kill the whole truck.
Robb is offline   Reply With Quote
Old 07-18-2009, 08:47 PM   #4
Did you mean to say,"it don't make sense".
That would make "more sense".
Ruger is offline   Reply With Quote
Old 07-24-2009, 01:33 AM   #5
www.WARCRC.org
justinart24's Avatar
Little something I made.
justinart24 is offline   Reply With Quote
Old 07-24-2009, 01:54 AM   #6
I guess that means the rx is powered too - any issues with that? instructions always tell you to power the transmitter on first but if you're switching on/off a few times in a session, I don't want to keep taking the body off - ok to leave it on for a while between sessions as the throttle is still powered by the esc which I'd turn off.
what would be the current draw while semi-off in this state?
mrklaw is offline   Reply With Quote
