| | #1 |
| Quarry Creeper Join Date: Jul 2009 Location: Utah
| I have been reading about dig and it seems that the punkRC dig unit will either lock front or rear, but will not allow freewheel, is that correct? Is there a dig unit or switch and servo setup for a MOA single esc that will allow you to select lock and freewheel on the rear axle? Those 2 options seem to be the most useful to me. Lock rear for tight turns and slower decents. Free wheel rear to keep from rolling backward on inclines. Thanks for your help. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Jun 2009 Location: SF
| MOA...motor on axle...digs are a bit different than what you're thinking about. Single motor digs control the fr or rr wheels with a servo operated mechanical lock in/lock out/free wheel and change only the rear axle. MOA digs electronicly lock the front and/or the rear axles to pivot on one or the other and as far as I've seen there is no setup to freewheel the back tires on a moa. |
| | #3 |
| Oh ok I see. So the only disadvantage then would be going up an incline. You would have to lock the rear which would prevent it fom flipping over, but the front would have to pull it up fighting the resistance of the rears not spinning. |
| | #4 |
| Pebble Pounder Join Date: Oct 2008 Location: KY
| you got it |
| | #5 | |
| I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
| | #6 |
| Yup, listen to oldhippie, read his reply 3 times and think about it. It's really something to watch a driverwho can really modulate his/her rear dig, amazing things can happen that defy gravity. |
| Thread Tools | |
| Display Modes | |
