Thread: LiPo or NiCd???? WHY
Old 07-19-2009, 03:54 PM   #1
Default LiPo or NiCd???? WHY
What batteries should i run and why? LiPo or NiCd? What are the pros and cons of the two? ill be powering two 55t fireball motors, through a rooster esc with two airtronic 94780 servos. my truck s a XTM X crawler. Also what size of battery should i run,? how many cells and mah?
JEDD is offline   Reply With Quote
Old 07-19-2009, 04:01 PM   #2
I'm Dracula, Bitch.
JeremyH's Avatar
Will your charger properly charge either battery?
JeremyH is online now   Reply With Quote
Old 07-19-2009, 04:09 PM   #3
i will get the charget when i get the batteries
Old 07-19-2009, 04:12 PM   #4
A we don't use nicds anymore. Nimh is what we use. Personally i run 3 cell lipo 2200 mah in my Berg just for the power. Each cell in a lipo is 3.7 volts per cell. and a nimh is 1.2 volts. Lipos don't drop in power like nimh do they have power all the way till you hit the lipo cut off. the only down side is that they are unstable if no used correctly. Make sure you have an ESC with lipo cut off and is set up for the number of cell you are running. 3.0 volts per cell is the cut off.so in my case i run 3 cell and its set to 9 volts. If you do not use an esc without lipo cutoff you will over discharge the pack and the next time you charge it. It will overcharge and most likely explode and start a fire. But in your case i would use Nimh better cause the safe and cheap and very easy to work with. No special charger is needed with a Nimh. But with lipos you need a special lipo charger with a balancer to balance the cell in the lipo so you have equal volts in each cell while charging.
I say use Nimh for now until you understand lipo better. But if you use lipo know the risk.
Flyin Hawaiian is offline   Reply With Quote
Old 07-19-2009, 04:19 PM   #5
I'm Dracula, Bitch.
JeremyH's Avatar
I would start off with Lipo. The batteries are lighter, smaller and will liven up your crawler nicely! IIRC, that Rooster can only handle 2S lipo....you can probably get good runtimes with a 1500mAh 2S. I run dual 35Ts on my Clod and my 1800mAh 3S lipo will last about an hour.
Old 07-19-2009, 05:16 PM   #6
Lipos are lighter and more powerful. for what ya got i would run 2cell lipo, anything over 20C and 1300mh,
oldhippie is offline   Reply With Quote
Old 07-19-2009, 07:03 PM   #7
what does the 2s and 3s mean? i could run a 1800mah lipo and have an hour of run time too? arent the lipo batteries smaller?
Old 07-19-2009, 07:07 PM   #8
WILL my rooster esc work with lipo batteries?
Old 07-19-2009, 07:25 PM   #9
2cell 7.4volt - 3cell 11.1 volt
Yes
In size, not power/capacity
2 cell only
Old 07-19-2009, 07:45 PM   #10
thanks alot OLDHIPPIE, what do you think i should use?
Old 07-19-2009, 07:58 PM   #11
what if i got with nimh battery, what mah should i get ???
Old 07-19-2009, 10:10 PM   #12
mah is what gives you the run time, so if you get a 5000mah you can run for a long time, but is gonna cost you more than a 1500mah, so its up to your budget as well.
somebody correct me if i'm wrong as i'm a newbie to electric, but that is my understanding.
ozpall is offline   Reply With Quote
Old 07-19-2009, 11:24 PM   #13
think of it like this'
mah is like your fuel tank, more mah, more fuel, more runtime.
2s lipo or 6 cell nimh would be like your engine, 2s would be like a v6 and 3s would be like a v8.
more cells = more power
kalin96 is offline   Reply With Quote
Old 07-19-2009, 11:49 PM   #14
exactly!!!
Old 07-20-2009, 12:38 AM   #15
Yup, you got it right Oscar
BJoe is offline   Reply With Quote
