Thread: best brushless for drag brake.
Old 07-20-2009, 09:52 AM   #1
Default best brushless for drag brake.
which brushless setup provide the best drag brake? i have the Ezrun 35T witch is worthless on the drag brake, it doesn't hold the truck at all on a incline.
wowo3180 is offline   Reply With Quote
Old 07-20-2009, 09:54 AM   #2
I'm Dracula, Bitch.
JeremyH's Avatar
A brushless motor will have very MINIMAL drag internally.....a brushed motor is what you want. Look for a motor with stronger magnets (Cobalt Puller)....
JeremyH is online now   Reply With Quote
Old 07-20-2009, 10:38 AM   #3
If you want to go brushless, you'll need a sensored setup with hill-hold function - you'll only find this on crawler-specific sensored systems like the Novak Goat.
clockworks is offline   Reply With Quote
Old 07-20-2009, 11:36 AM   #4
does anyone has Novak Goat? how does preform? how strong is the drag brake?
Old 07-20-2009, 12:57 PM   #5
I've got a Goat in my Venom Creeper. I just tried testing the hill-hold brake. The only thing I had to use as a variable incline was an old wooden shelf.
With the ESC switched off (no drag/hill-hold brakes, just motor/transmission resistance), it would hold on a 10 degree incline.
With the ESC on, and the brakes set on "2" (out of 9 levels), it would hold on a 15 degree slope.
With the ESC set to "9", it was still holding on a 45 degree slope, although the tyres were starting to slide on the varnished wood!
Seems pretty effective to me.
Old 07-20-2009, 01:43 PM   #6
Dream...Think...Create.
Nova's Ark's Avatar
I ran a Mamba Max, CC BEC, 3S lipo and Holmes Hobbies 1000KV Crawl Master all of last season in my 2.2 comp rig. It held awesome! With the drag brake set to 100% it held on an incline or decline. My gearing was 96 tooth spur and 18 tooth pinion on a Axial transmission.
The only brushed motor I have seen with comparable hold is a Holmes Cobalt motor in my experience.
Now I hear that the Tekin FXR with a Hand Wound motor will hold excellent but since I do not own one I cannot verify personally.
Nova's Ark is offline   Reply With Quote
