Thread: Difference between warriors
Old 07-20-2009, 05:50 PM   #1
Default Difference between warriors
On the jpcustomrcs there are several warrior motors. What are the differences between them? I want really good torque, with good wheel speed. I don't want so much wheel speed that it can run around almost like a basher though. I will be running on the Havoc bully 2's, 3s lipo, dual fxr esc's, and a hitec 5990 servo.
Thanks
mhuffman_81 is offline   Reply With Quote
Old 07-20-2009, 06:23 PM   #2
40 or 45t's should be good if your planning on using 3s
Failedabortion is offline   Reply With Quote
Old 07-20-2009, 06:44 PM   #3
X2 I'm running regular 45s on 3s (not really enough for me), Just got 40t warriors (didn't go 35s because I been told I'm a throttle jockey)
oldhippie is offline   Reply With Quote
Old 07-20-2009, 06:46 PM   #4
Thanks
Sounds like you are upgrading to a real comp setup-KOOL
Old 07-20-2009, 07:05 PM   #5
Rockcrawler's Avatar
http://www.rccrawler.com/forum/showthread.php?t=181506
Rockcrawler is offline   Reply With Quote
Old 07-20-2009, 07:08 PM   #6
Yeah my finances have changed a bit and I'd rather not buy cheaper stuff and upgrade later, so i'm trying to get closer to top of the line to start with. Only things I am not upgrading are the wheels, shocks, torsion bars, and steering kit, will all be what comes in the kit. I'm sure they will be fine for a while. I will experiment with tires for a while and then get some nice wheels. Here is my current list:
Havoc ARTR kit including:
Bully2 axles
4x 2.2 X-Locks
4x Plastic beadlocks
HaVoc Plates
2in Skid
4x Upper Links 114mm
2x 70mm Shocks
2x 68mm Torsion Links
4x Bent Lower Links
1x Rc4wd Steering Kit
Castle BEC
Tekin FXR 55t combo x2
Hitec 5990tg Servo
Futaba 4pk
Hyperion 3s 2600mAH 35/65c x2 (Should fit inside the belly of the chassis)
Hyperion EOS 0606I AC/DC Charger
JConcepts Stage Killah Body
Only thing I might change will be the FXR combos, might just get the esc's and go for some warrior motors.
Old 07-20-2009, 07:51 PM   #7
Gold Star Baby!
Stormin2u's Avatar
Location: Taylors Falls just hanging with the MNRCRC crew.
I have one of the first 35x1 Warriors and I love it. The dyno tells me it produces its power very efficiently as well. I run mine on 3s packs but as efficient it is it could probably run on 2s without a problem.
Lots of torque and plenty of wheel speed and the new ones are better.
Stormin2u is offline   Reply With Quote
Old 07-20-2009, 10:27 PM   #8
Bully2 axles
4x 2.2 X-Locks
HaVoc Plates
2in Skid
2x 70mm Shocks
4x Bent Lower Links
Castle BEC
Hitec 5990tg Servo
Futaba 4pk
That should be a great setup. Only thing left are some wheels, 400+servo and big bore shocks, but it will be while before you'll tell the difference I bet. The warriors are great motors but the 35/45 combos on 3s are really more than most anyone needs. But don't think I ever believe there is such a thing as too much power. Lets see a build thread!
