07-21-2009, 11:46 AM | #1 |
Rock Stacker Join Date: Jan 2009 Location: Toronto
| Mamba Max question
I have a Mamba max with a Venom 55t, and a hitec servo. Since using it in my crawler, I've had to reverse the steering and throttle on the radio (DX2). Is there something I have I done wrong in the programming of the MMax? FYI - I use the same radio profile for another TC with a Novak GTB in it as my end points are set the same, but I have to switch the throttle and servo back to normal. |
07-21-2009, 12:10 PM | #2 |
Quarry Creeper Join Date: May 2008 Location: looking for sponsors
its just how your rig is set up theres nothing wrong at all but you can reverse the throttle on the mamba max's castle link |
07-21-2009, 12:21 PM | #3 |
It's not a big deal, but I thought it was strange because I have another Mamba Max in a DF03 that I use with the same radio, though on a different profile, and it's set to normal?
07-21-2009, 01:29 PM | #4 |
It sounds like on one of the motors, you have the leads installed backward...
07-21-2009, 01:33 PM | #5 |
I thought that in the beginning, but then I realized that it was faster in reverse than fwd so I swapped them around, and reversed the throttle.
07-21-2009, 01:41 PM | #6 |
Reverse throttle percentage is a selectable function during the programming process of the CC ESC....
