07-23-2009, 11:24 AM | #1 |
Pebble Pounder Join Date: Jun 2005 Location: Millerton, PA
| Do i need resistors or capacitors? 55t lathe
Hi there. Been outta the game for a while. Just picked up an Integy 55t Lathe and I'm wondering if i need to solder in some capacitors or resistors or diodes or whatever those things are I see on some motors. I'm Also curious if it matters which 'side' is positive or negative, as its not marked on the can or backing plate. Thanks in advance.
07-23-2009, 11:51 AM | #2 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
are you running a 2.4ghz? The capacitors are to help with interference from the motor. There should be a square with a + in it on the positive side stamped into the plastic end bell. It can be run either way anyways so it doesn't matter to much. Last edited by Failedabortion; 07-23-2009 at 11:54 AM. |
07-23-2009, 12:12 PM | #3 |
I run these on my brushed motors: http://www3.towerhobbies.com/cgi-bin...1&I=LXBJ87&P=K Are they needed? Probably not on these hig turn, low amp draw motors, but they sure as hell dont hurt... Here's a good "how to" for installing caps: http://www.misbehavin-rc.com/pit-lane/motor/g-motor.asp |
07-23-2009, 12:16 PM | #4 |
Thanks for the response. I said I've been out of the game a while I'm using a Hitec Lynx FM radio with a Tekin Rebel 2 esc. I currently have a 19TDouble trinity Monsters of touring (only motor i had) in the pede trans, and I dont have any problems (other than being too fast to crawl). I'm gonna try to run this motor without a cap and see how it does.
