07-23-2009, 05:46 PM | #1 |
Newbie Join Date: Jul 2009 Location: Down by da beach
| Question about tamiya 3 speed for high lift
Hello, If i use a 2 speed transmitter and remote for the hilux high lift i know i wont be able to shift gears but will i be able to choose the gear i want to run? ie i want to just run 2nd gear. for example i have factory traxxas xl5 esc and transmitter from a slash. I want to throw that into the high lift until i can afford the 4 channel. someone with a high lift can you enlighten this noob? |
07-24-2009, 05:46 PM | #2 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
You can manually lock the trans in any of the 3 gears. I think the instructions will show you how somewhere. If not, jusr use a collar with a set screw to hold the shift shaft in position.
