07-24-2009, 06:23 PM | #1 |
RCC Addict Join Date: Dec 2005 Location: Tucson
| Sidewinder and 2 550 titans
Will a sidewinder handle 2 550 titan 21T or 23T for the Losi MOA set up or should i get a MM or use 2 sidewinders?
07-27-2009, 09:44 PM | #2 |
anyone know i want to try it in a LCC MOA
07-28-2009, 09:04 AM | #3 |
I would think that they would work fine on a single Sidewinder. I don't know the continuous amp on it. I know the MM is 100amps. It prolly around 75amps or so.
07-28-2009, 09:06 AM | #4 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
they should work just fine. The only problem I see is actually fitting them between the links. a 540 fits pretty snug.
07-28-2009, 11:33 AM | #5 |
Eritex has two cobalt pullers in his. i going to try it
07-29-2009, 12:43 AM | #6 |
Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
The puller is longer and 540 is a little wider.
07-29-2009, 06:55 AM | #7 |
07-29-2009, 08:33 AM | #8 |
EMaxx Titan 27T 550 motor specs are: Length to end of Armature: 78mm or 3.07" Diameter of Can: 37mm or 1.46" |
07-29-2009, 09:14 AM | #9 |
7T puller measurements are 2.5" long 1.35" diameter |
