Thread: Max Charge rate?
Old 07-24-2009, 11:52 PM   #1
Default Max Charge rate?
Hey I got a Tenergy 5000 nimh 7 cell stick pack. I was wondering what the max amp charge rate is? Thanks in advance Scott.
boisetrucker is offline   Reply With Quote
Old 07-25-2009, 12:14 AM   #2
i normally charge my stick packs at 4 amps
but your can go lower or higher
max id go is 6 amps though
life_livin is offline   Reply With Quote
Old 07-25-2009, 12:22 AM   #3
Max "safe" charge for that pack would be 5 amps.
Safe Charge amps go by the Mah of the pack.
IE:
1000Mah = 1amp
2000Mah = 2amps
etc
etc.
ScalerLover is offline   Reply With Quote
Old 07-25-2009, 12:23 AM   #4
Appreciate it thanks. I was also wondering what the volts should be at full charge.
Old 07-25-2009, 12:29 AM   #5
Around 10.5 to 11v when freshly charged.
clockworks is offline   Reply With Quote
Old 07-25-2009, 01:22 AM   #6
I always go a little less than the max:
On my 5000mah I charge at 4900
On my 800mah I charge at .7
Don't know if it helps but it can't hurt, just takes a little bit longer.
RustlerHustler is offline   Reply With Quote
