07-25-2009, 03:16 PM | #1 |
Quarry Creeper Join Date: Sep 2006 Location: Jackson
| Xceleron Help
I have the Xceleron 17.5 system for my Losi and I have never even installed it yet. I read somewhere here that you can take the delay out of the reverse, but in my computer setup, there is either reverse with delay or no reverse, I can't find anywhere to take the delay out.
07-25-2009, 04:12 PM | #2 |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
is there a fwd-brake-reverse setting?
07-25-2009, 06:21 PM | #3 |
no, there is a forward only setting, and a f-r with a 2 sec delay, no other choices
07-25-2009, 07:50 PM | #4 |
Rock Crawler Join Date: Apr 2009 Location: NorCal
sorry,,,,,,, for now that's as good as it gets,,,hopefully when they get the crawler versin out we will be able to get the firmware and boot it in our esc's. You may have read were a few have reversed the motor direction, then reverse the throttle servo in the radio giving you instant rev to forward ( your using reverse for going forward,,understand?) The down side is now your dely in going the other way (not so bad). Make sure you have the reverse 100% on in your esc so you can get full throtle going forward (while in reverse,,confussed yet?) I did not do this and not sure if it really works, and may have not remembered it the way it was posted before. I just got used to hitting center before hitting brake. I use a stick radio for now so the stick is spring loaded and returns quite fast to nuetrul so I live with it for now,,,,,,good luck and I think you will REALLY like the set up,,,I run a 12t pinion and am quite happy with it. As far as heat build up I got tiered of worring about it and got another fan and hung it here for peace of mind,,,, |
