07-25-2009, 04:42 PM | #1 |
Pebble Pounder Join Date: Jun 2009 Location: Florence
| Sidewinder problem?
just put in banebot motors and a sidewinder esc. i did the quick program that is in the book. the problem is when i pull the throttle the truck just sits there and rocks back and forth about a half inch back and forth. reverse does the same thing. the steering works just fine. both motors are turning the same way and if i pick the truck up it still does the same thing. what could be causing this?
07-25-2009, 04:47 PM | #2 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
is your motor brushed or brushless. make sure the esc is programed correctly. they come set brushless out of the box.
07-25-2009, 05:00 PM | #3 |
Quarry Creeper Join Date: Jun 2009 Location: Abbotsford BC Canada
Also check for lipo cut off.What battery are you using?
07-25-2009, 05:08 PM | #4 |
07-25-2009, 05:34 PM | #5 |
its brushed motors and im using these packs. http://www3.towerhobbies.com/cgi-bin...&I=LXVTE6&P=ML this is in a cliff climber. is the only way to change it over to a brushed motor is to hook it up to a pc? if so ill need to get the wire to hook it up. thanks for the help this is good info so far.
07-25-2009, 07:32 PM | #6 |
Newbie Join Date: Aug 2007 Location: Lancaster
You need one of these http://www3.towerhobbies.com/cgi-bin...?&I=LXGVR8&P=7 |
07-25-2009, 09:18 PM | #7 | |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
