07-25-2009, 07:22 PM | #1 |
Newbie Join Date: Jan 2006 Location: Glendora, CA
| Modern radio/reciever suggestions?
parting back together my collection of R/C's and finding i have a lack of radio gear. what little i do have is so old I'm not even sure it will power up. Have been glancing at newer radio systems, but honestly I am lost for what i should be looking for. Want something thats just as good for my bashers as it is for my comp. vehicles AND still economical. Thought I saw where I could one radio with more than one vehicle, is this possible?? Ideally I would love to have maybe 2-3 hand-helds running my collection, 10+ vehicles currently. thanks for the help --B |
07-25-2009, 07:30 PM | #2 |
Quarry Creeper Join Date: Aug 2008 Location: in the basement cussing my broke ass rig
| Yes. You can purchase multiple Rx's and run them with one Tx. Some Tx's have model memories for different settings on different models which would be good for your situation. I would recommend a Futaba 2.4 GHz system. They can be somewhat affordable used. Hope that helps a little... |
07-25-2009, 07:36 PM | #3 | |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
I'm saving for a Futaba 4PK myself. Read through Harleys write-up on it, and you'll want one too. Very, very versatile... | |
07-25-2009, 07:57 PM | #4 |
RCC Addict Join Date: Nov 2007 Location: BV
There are lots of good radios on the market. I'd say you should get something with at least 3 channels, the third channel needs to have at least 3 selectable positions and you should get something with end point adjustments. Digital servos will burn up without proper EPA settings. I'd also advise 2.4ghz, they work pretty damn well. For your non crawling needs, dual rates and ABS are pretty nice but not essential. The futaba 4PK is hands down the nicest radio on the market. It's price reflects this The 3PK is almost as nice as the 4PK and is somewhat cheaper. The current 3PM is a pretty nice radio, but you have to do some fairly awkward things to get a 3 position 3rd channel. Otherwise it's great. They'll be coming out with a new 3PM variant pretty soon which has more useful crawling features. I'm sure it's gonna be a great entry level crawling radio. The spektrum DX3R is a nice radio also. It's very comfortable and light, has a good 3 position 3rd channel among other things. Hard to go wrong there. Spektrum also makes the DX3.0 and the DX3S, but neither has a 3 position third channel. The KO Propo EX-5 UR has up to 5 third channel positions, comes with 2 receivers and is very reasonably priced. I've never actually seen one, but KO makes good stuff. KO also makes the EX-1 UR, which is a 4 channel radio. It has no mixing, so you won't be able to run dual ESC's with it, but it's pretty nice otherwise. Up to 5 third and fourth channel positions. If you're comfortable with buying used, look into the JR R-1, Futaba 3PJ or Spektrum DX3 (not 3.0) all are nice radios, the DX3 requires some modification for the 3rd channel switch. The R-1 and 3PJ are module radios and can be fitted with 2.4ghz modules. |
07-25-2009, 08:31 PM | #5 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
I used to be alot like that and have several stocker radios. You ask for an econimical radio that will work for you and you honestly cant go wrong just going 2.4gHz and get say a spektrum DX3R which if I am correct will hold more than 10 setup's. You can easily switch out your reciever if you dont want to have several. and in the mong run it will be nothing less than the best purchase you have ever made. I myself have a DX3S but i find that I should of gone to the 3R for the use of the 3 position 3rd channel. No biggy for me as I make due. But over all I am happy
07-26-2009, 09:43 AM | #6 |
Pebble Pounder Join Date: Dec 2008 Location: Tomball, Tx
My son has a 3PK-S that I would recommend for what you are wanting to do. It is kind of pricey (to me at least), but the best feature is the interchangeable transmitter 'modules' He can swap from his FAAST module to a FM module and use his trans with any of my (old school) receivers. It can even run spectrum receivers with another module. This TX can do just about everything you need, but wipe your...... there might even be a module for that too. My radio is an older Magnum 2PL (75Mhz) that has a 10 model memory. It works ok for me, but I would rather have a 2.4Ghz radio so I don't worry about stepping on somebody else on the same freq. |
07-27-2009, 02:55 PM | #7 |
thanks for the suggestions, only a few days till pay day and its already burning a hole in my pocket!
07-27-2009, 03:59 PM | #8 |
Pebble Pounder Join Date: Aug 2008 Location: Cary, NC
| Radio
Brandxman, PM Sent |
07-27-2009, 05:10 PM | #9 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
Do you want a pistol or twin stick? I prefer a pistol grip for racing, but I've come to really like a twin stick for crawling. The DX6i is a 6 channel 2.4ghz that can be had for about $150 with 1 receiver. Additional receivers can be had new for $50 each ($30 -$40 cheaper than other radios). You'll need ot send the radio back to Horizon to have a return spring put on the left stick, but they'll do it for the cost of shipping. ...and you get a ton of channels which come in handy for scalers. Otherwise, I'm a big fan of the DX3r. |
07-30-2009, 05:52 PM | #10 |
ok got a little to think about here. one more question for ya. I use to mix and match brand names for Tx and Rx as long as they were the same type and had the same cryatal in them all was good. Is this still possible with the Futaba FASST systems? or is it their 2.4 only??
07-30-2009, 05:59 PM | #11 |
Just 2.4, You cant do the crystals in the 2.4's another route you m ight want if you dont want to spend a whole lot is check out this. RC4WD's radio has been highly praised. they have 2 different radios, but I hear they are really nice. http://www.rc4wdstore.com/2/product_...roducts_id=615 http://www.rc4wdstore.com/2/product_...roducts_id=616 |
07-30-2009, 07:29 PM | #12 | |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
