Thread: I need to change my balancing taps, help please
Old 07-26-2009, 02:32 PM   #1
Default I need to change my balancing taps, help please
Alright guys i have a losi 2s lipo for my crawler but my charger is only capable of charging the JST style, there for i need a converter(duno where to buy) or snip the end off n re do
I dont mind putting a new connector on but on the losi lipo there are 3 wires RED BLUE BLACk and i dont know where these go on the JST connector?
Thanks in advance
Craig
craigrobbo is offline   Reply With Quote
Old 07-26-2009, 07:34 PM   #2
Here is what i did for my son's batteries. Our chargers take the 'standard-ish' JST xh series connectors. His NEU batteries have a JST eh series connector...seems to be the same as on the losi battery. look at the narrow side of your balance connector. There should be two 'ridges' on each side. If you file these down, it will then fit into the xh connector on your balance board. Hold on there cause you're not done yet. The leads are in the wrong order. On one of the wide sides of your connector there are little tabs that hold the contacts into the connector. GENTLY pry one of these up and pull the contact out. For your 2s you will need to swap the two outer wires. DON'T let the wires touch! I found out the hard way with a 6s!
HTH
rex cars is offline   Reply With Quote
Old 07-27-2009, 10:16 AM   #3
go to cheapbatterypacks.com and look for the adapter. not expensive, $5-$10. worth not frying a battery.
robsdak is offline   Reply With Quote
