07-27-2009, 09:47 AM | #1 |
Newbie Join Date: Jun 2009 Location: Rushsylvania
| aluminum servo horn
Where can I find an aluminum servo horn for my Hitec 645 cheap. It is going on an AX10.
07-27-2009, 09:56 AM | #2 |
Quarry Creeper Join Date: Feb 2008 Location: EAST TN WHERE SHINE IS FREE
lhs |
07-27-2009, 09:59 AM | #3 |
Rock Crawler Join Date: Feb 2008 Location: UK
The cheap ones that I've seen are universal and come with plastic inserts for the 3 different spline fittings (23, 24 and 25 splines). Not really worth buying as the plastic insert is a potential weak point. Hitec supply a proper aluminium servo arm with their high-end servos, but it's a bit short for a crawler. Best buy is the Robitronic 24 spline arm. This fits properly, has 2 extra clamping bolts and is virtually indestructable. It's available under several different brand names. $10 should get you one. |
07-27-2009, 10:44 AM | #4 |
Newbie Join Date: Jan 2005 Location: Boston
Thanks for the input Clockworks!
07-27-2009, 11:02 AM | #5 |
Robitronics is the best servo horn you can buy. I swear I will run these on every hardcore build from now on. Once you see one you will understand.
07-27-2009, 12:07 PM | #6 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
I'm running the same basic horn as the robotronics one but mine is from Racers Edge.
07-27-2009, 12:09 PM | #7 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
IMO the next best to the Robitronics would be the Losi ones. Link below. http://www.horizonhobby.com/Products...odID=LOSA99033 Very beefy, they are solid aluminum, no plastic insert to round off. Their only negative is that they might be a bit short depending on your application. Narly1 |
07-27-2009, 12:20 PM | #8 |
Thanks for the info everybody.
