08-06-2009, 12:26 PM | #21 | |
Quarry Creeper Join Date: Jul 2005 Location: Utah
As of now I played with my programmer and got my steering to work almost perfect. I still dont get 180* of travel with the rear servo that I would like. For some reason when I try to program my 5995 I end up with less travel then the factory settings, so all I can do with that servo is set the Dead Band Width. The servo is already programmed to 180* so I guess I wouldnt get any more with the programmer, I just think it is odd that I get less. | |
08-06-2009, 12:43 PM | #22 | |
Rock Crawler Join Date: Feb 2008 Location: UK
Nearly all standard pots rotate through 270 degrees or so of rotation. Put the pot in a Tx, and it simply can't rotate that far. 60 to 120 degrees seems to be normal. If you wire a standard pot (left loose, not fitted to the stick) in place of the Tx's pot, you'll get much more movement at the servo - up to double with one Tx that I've modified. Computer Txs offer the option to overdrive the servo, up to 150% in some models. This goes some way to overcoming the problem. | |
08-06-2009, 01:49 PM | #23 | |
Quarry Creeper Join Date: Apr 2009 Location: Ottawa, ON, Canada
Besides, I don't even want a 'neutral' position anyways as my old radios don't have neutral at the same place. Richard | |
08-06-2009, 01:54 PM | #24 | |
Richard | |
08-06-2009, 02:43 PM | #25 | |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
Most servos can travel past 180. Most radios are set up for about 90 degrees servo travel at 100%. I don't any radios that will push them to 180. That's what what the stretcher is for. | |
08-06-2009, 04:39 PM | #26 | |
I did this with my hybrid 6ch pistol Tx (DX6i electronics in a KO Mars case). A 5K pot, with full 270 degree travel, gave much more travel than the ch2 stick on the original DX6i. Same on my current project (Turborix 6ch into cheap Chinese pistol case). A full rotation pot puts travel off the scale in the setup software. | |
