07-28-2009, 06:49 PM | #1 |
Quarry Creeper Join Date: Aug 2008 Location: bradenton
| Brush or Brushless
brushed 2 cell lipo or 3 cell brushless 2 cell lipo or 3 cell Pro's & Cons on Brush or Brushless .I have never used a brushless motor:? |
08-04-2009, 02:43 PM | #2 |
Pebble Pounder Join Date: Jun 2009 Location: Jackson
Can't quite make sense out of your 1st sentance, but I have the same question. Brushed or brushless? |
08-04-2009, 02:48 PM | #3 |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
the thing that i found with brushless out runners was they cogged(jerked alot) at low speeds. also the inrunners that i have tried the drag brak wasnt up to par. i use a brushed motor on three cell lipo. it gives you great low end throttle control and a good drag break. |
08-04-2009, 03:44 PM | #4 | |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
If you go brusless---inrunner is your only "good" option... | |
08-04-2009, 04:13 PM | #5 |
Pebble Pounder Join Date: Jan 2009 Location: Planet Earth
Novak makes two good setups. If you go with the brushless, it might feel a little smoother and will run like new for much longer. It doesn't seem to hold as well with brushless with a drag brake, but it still works fine. If you go with the Novak 55 setup, it looses a little of its slow end accuracy and control, but it has a better drag brake ability. I myself run brushed. Right now I am running an Integy 65T. It works really well for me. I only run a six cell NiHm so i use a higher turn for better control that I don't get from a higher voltage pack. Brushed takes some maintinance to keep it running well. You have to clean the brushes every so often, and rebuild it every year or so. Brushless is a lot less work. This is my opinion though.
08-04-2009, 04:27 PM | #6 |
I run brushed in my comp rigs, and brushless in my bashers. Sensored is the way to go for brushless stuff if you want great low speed control, but sensorless can be pretty cheap.
