08-02-2009, 10:28 PM | #1 |
Rock Stacker Join Date: Jun 2007 Location: Abbotsford BC
| Axial RTC electronics problem.
I bought an axial RTC, plugged the battery in and the throttle trim was so out of wack that I couldnt adjust it to where it would stop going without the throttle. I reversed the throttle switch and that stopped it, but my throttle was backward... I switched the motor wires around and then it worked ok. But it is still very glitchy, I tried a different transmitter, and it was no better... is my speed control jacked? anybody else have this problem?
08-02-2009, 10:33 PM | #2 |
Quarry Creeper Join Date: Feb 2009 Location: Conowingo, Maryland
are your reciever and esc real close? if the are move them apart and see if that helps.
08-02-2009, 10:48 PM | #3 |
08-03-2009, 01:25 AM | #4 |
Newbie Join Date: Jun 2009 Location: Malaysia
I am having some ESC (stock) problems with my RTC which comes with a 55T motor (stock). Recently installed a 3racing dig unit which requires reversing the motor & transmission mount. Ensured that there was no binding in the dig servo. There is also no binding on the transmission and shafts. The rig would run fine for a period of 5 minutes. Then the ESC would get really hot and shut down. Got rid of the cable tie which was holding the esc down and placed the esc on its side to expose more surface area for improved cooling. Now the rig lasts about 10-15 minutes. The ESC still gets really hot and still shuts down. What could be the cause? Note that the motor (which was mounted in reverse to fit dig unit) sits much closer to the ESC now. And the ESC sits right next to the receiver. Could any of these be a possible problem? Appreciate your response guys. p.s. Rock crawling is a realatively new sport here in Malaysia. Hence not much support in terms of advice and hardware. Heck, I bet most of you havent even heard of this country:-P |
08-03-2009, 01:36 AM | #5 |
Newbie Join Date: Jan 2009 Location: Stillwater
To the OP - my kid's RTR did this. It was all in the startup sequence. My kid was holding the trigger before the ESC beeped. Try centering the throttle adjustment, and then turn on the tx. Without touching the trigger, turn on the rx and wait for beeps before touching anything else. wjong - I would guess that you have a proximity issue and things are overheating - if you had no troubles before the modifications. Try separating the esc and motor to see what happens. If this fixes it, you might consider moving the ESC to a lower and further away spot (like on a plate that's mounted to the links). |
08-03-2009, 07:30 AM | #6 | |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
08-03-2009, 06:43 PM | #7 | |
I ordered a Novak Rooster Crawler from ebay a week ago. The item should be arriving anytime now. I believe the esc comes with a built-in BEC. Hence, I'll just shelf the rig for a few days till the Rooster Crawler arrives. | |
08-04-2009, 02:34 PM | #8 |
Rock Stacker Join Date: Jun 2009 Location: Fair Oaks
what sparky said. my bro has an rtr and i have the rtc and they both freak out if you turn the rig on before the controller or if you do anything with the controller before the rig beeps. turn on your controller and set it down, then turn on your rig and wait for the beeps
08-04-2009, 03:02 PM | #9 | |
Hateraide Join Date: Dec 2008 Location: Mission BC
you should still order yourself or buy a castle bec you cant go wrong buying one it will save you ever having a problem | |
08-04-2009, 03:22 PM | #10 |
Rock Crawler Join Date: Mar 2008 Location: lodi
novak roosters dont go well with cc bec's >_< they glitch heavly the internal bec is ok if ur just playing around and havign fun if your wanting to do comps look into a cc sidewinder/mamba max or tekin fxr and run a cc bec you will not have any glitching problems and be able to run higher then 2s lipo
08-04-2009, 03:28 PM | #11 |
Quarry Creeper Join Date: May 2008 Location: looking for sponsors
i pull the signal wire out of all my becs and it stops glitching (well the glitching caused by the bec)
