08-06-2009, 11:43 PM | #1 |
Quarry Creeper Join Date: Nov 2008 Location: Lightin' The Desert In
| Discharge
How Can You COMPLETELY Discharge A Battery If You Dont Have A Dischager? Ive Got A 4600 Trinity Battery I Wanna EMPTY It Out;An Get A Full Charge On It. How Would I Discharge It If I Dont Have A Discharger? |
08-06-2009, 11:44 PM | #2 |
Quarry Creeper Join Date: Feb 2009 Location: Conowingo, Maryland
is it a nimh? i thought you were only suppose to completely discharge nicd's?
08-06-2009, 11:51 PM | #3 |
NIMH. Ive Wondered About Discharging It; But IDK How; Ive Got a Duratrax Piraha Charger; 4 3300 Batteries; 2 3000 batteries An 2 4600; Ive Got A Stock Rustler; Novak Havoc 10.5 BL An My 4600 Battery Life is About GONE; Wondered If I Need To Discharge It? Or What Cause I Cant Run It Cause My ESC Shuts Down Cause OF Low Voltage Cut Off; I Wanna Run A MaxAmps Lipo an Charger; But Im IFFY On Lipos Cause Of The Hazards They Have; ? |
08-06-2009, 11:55 PM | #4 |
ive always used nimh cells and had a lipo for a week. i just stick with what i know works. try pming maxamps and see what he can recommend lipo wise for you?
08-06-2009, 11:56 PM | #5 |
Im Currious On How Do I Discharge A NIMH Battery? |
08-07-2009, 12:01 AM | #6 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Stick pack or side by side cells?
08-07-2009, 12:04 AM | #7 |
6 Celll Stick With Deans
08-07-2009, 12:18 AM | #8 |
I guess something like this..... not sure exactly where to get them anymore though. |
08-07-2009, 12:18 AM | #9 |
Quarry Creeper Join Date: Jul 2008 Location: peoria
hook it to a lightbulb
08-07-2009, 12:35 AM | #10 |
Newbie Join Date: Dec 2008 Location: Payson
NiMih's; it is recommended not to go below 0.9v per cell. But if you must, directly connect a motor or auto tail light bulb. It will take a little time but will get your pack to zero and possibly damage some cells and really messing up the pack. For LiPo's http://maxamps.com/lipo-care.php. I will add, follow the instructions of the Battery & Charger manufacturer. You will have no reason to fear a LiPo. |
08-07-2009, 01:19 AM | #11 |
Alright; thanks for the help; Ive got a 10.5 havoc in my rustler; an was wondering if a RTR rustler vxl kit from MAXAMPS will be good for it? The batteries ive got now are killin my run time; an ive always feare LIPO cause of the hazards; but i think MAX has good packs, an i was wondering if its good for it? Never tinkering with Lipo cause ive been cautious with them.. |
08-07-2009, 01:23 AM | #12 |
08-07-2009, 05:16 AM | #13 |
Why do you think you need a discharger to get a full charge for NiMh's? Run it in your vehicle until it's slow, then put it on the charger. You will get a full charge. You don't need to do any discharging voodoo tricks for crawling. Simply not necessary. Leave that stuff for the racers that are trying to get the last 0.001 volt. |
08-07-2009, 12:00 PM | #14 |
I Cant Run My Nimh Battery In My Havoc Cause Its got Low Voltage Cuttoff an It shuts Itself Down
08-07-2009, 12:27 PM | #15 |
Rock Crawler Join Date: Jan 2005 Location: Windsor, VA
You can build something like the deans bulb discharger posted above. I bought 10 automotive tail light bulbs and wired them together to build a 30 amp discharger. I don't use this on anything but 6 cell packs, I have a smaller two bulb discharger I made for my crawler packs before I got my new charger with a discharger built in. |
08-07-2009, 12:45 PM | #16 |
08-07-2009, 01:26 PM | #17 |
Pebble Pounder Join Date: Aug 2009 Location: ST. George
I was told by an electrical engineer that nimh batteries can develop a "memory" so you shouldn't run them completely out.
08-07-2009, 03:08 PM | #18 |
Sorry To Everyone; Ive Got NICAD Packs Not NIMH. |
08-07-2009, 03:08 PM | #19 |
08-07-2009, 03:18 PM | #20 |
Quarry Creeper Join Date: Mar 2009 Location: Torrance, CA
Recycle the Nicads and get something new. They would need to be cycled a few times and even that may not work. Everything has a lifespan. I've also read that many brushless ESC with voltage cutoff won't work with older batteries because of the discharge rate or something. Your motor is basically pulling too much power, more than the battery can discharge, so the ESC is thinking it's low voltage when it's not.
